Sputtering 460
Old Jan 18, 2003 | 07:27 PM
nolanc2's Avatar
nolanc2
Sputtering 460
After a mud race last night my 460 sounds like its loading-up, revs fine in park but when I put it in gear it hesitates a little, still spins the 38 inch tires but when I stop after a bought 80 feet it loads up so bad it wont hardly take off again, give it a few seconds and it will do ok again but still not good. Even with just a little throttle it will spit and sputter. The carb is a new 750 edelbrock on an Offenhouser intake the carb was working fine before. I recently installed a new cam and lifter set 262/272 duration and 479/504 lift, left stock springs. I have changed all plug wires and checked all plugs also checked timing. I have an electric fuel pump that pumps 20-30 gph open flow thinking I may be running out of fuel bought new Holley pump 97 gph haven’t hooked it up yet.
I’m new to the engine-building world any help would be appreciated.
Old Jan 19, 2003 | 10:48 PM
nolanc2's Avatar
nolanc2
Sputtering 460
I installed my new fuel pump but that is not the problem, I’m still stumped
Old Jan 19, 2003 | 11:09 PM
Ratsmoker's Avatar
Ratsmoker
Sputtering 460
Make for certain that you don't have an gremlins in the ignition system. It could be any number of things. How long was the carb off? It takes not time for it to start to dry rot on the bench. Not real familiar with the edel carbs. Sounds like the carb to me. Is the choke sticking? Rig the choke to stay open all the time. See if the problem still persists. Probably gonna take some time to shoot down. Your vaccum or mechanical advance could be sticking. Good Luck!
Old Jan 19, 2003 | 11:22 PM
nolanc2's Avatar
nolanc2
Sputtering 460
Thanks for the reply I have a new coil new cap and rotor new plug wires and the carb is also new got it from Jegs last week.
I did notice a water leak on my intake manifold near the #1 cylinder, could the water also be leaking into the intake port of the head and dropping into the #1 cylinder? I will change the intake gasket tomorrow, it needs to be done anyway this time I won’t get in a hurry and I’ll torque to spec.
Old Jan 19, 2003 | 11:32 PM
Ratsmoker's Avatar
Ratsmoker
Sputtering 460
That could do it too. Use black RTV evenly around the water ports in the head and on the intake and you won't go wrong.
Old Jan 19, 2003 | 11:38 PM
nolanc2's Avatar
nolanc2
Sputtering 460
Thanks for the tip.
Old Jan 20, 2003 | 08:54 AM
georgedavila's Avatar
georgedavila
Sputtering 460
Sounds like the float valve could be sticking in the open position.
Is there a reason you didn't change springs for the new cam?
Old Jan 20, 2003 | 02:22 PM
jberylecrider's Avatar
jberylecrider
Sputtering 460
This happens to me & buddies all the time when we mud/water race...
It is almost always water under the cap on the dist and/or wet or damp airfilter!
It is usually both problems together.
Check those two things. Thoroghly dry your cap & points, then airfilter, housing & all ducts.
Hope that helps. I know its basic stuff, but people overlook the little things sometimes.
Old Jan 21, 2003 | 10:48 AM
rabidranger's Avatar
rabidranger
Sputtering 460
I am with jberylecrider, my 302 ranger would run like crap after runnin in the mud or water. But a dry rag and some wd-40 under the dissy cap would clear it right up.
Old Jan 22, 2003 | 10:50 AM
nolanc2's Avatar
nolanc2
Sputtering 460
Thanks for the help; the dist. cap was the first thing I looked at since it’s on the front of the engine right behind the fan.
You’ll get A laugh out of this one, turned out to be old gas, the truck only gets run allot during racing season. I know, all that new stuff and I failed to clean the tank.
I left the old valve springs because I was running out of race truck money.
Blue Rebel
Jan 31, 2015 10:52 PM
mustang_gt_350
Aug 19, 2014 01:50 PM
75 Camper Special
May 17, 2014 02:41 PM
f1001969mike
1978 - 1996 Big Bronco
Sep 9, 2013 07:34 PM
