460 Fuel Pump Volume
Old May 16, 2014 | 11:13 PM
75 Camper Special's Avatar
75 Camper Special
Just wondering if anyone knows what the GPH rating is on the 75 460 factory mechanical fuel pump. Thanks
Old May 17, 2014 | 12:18 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
No, but here is some interesting information for you.
Ford 351M and 400 fuel pumps put out about 7 psi if "spot on".
Holley and Motorcraft Carbs can take in excess of 7 psi due to longer float arms with large floats. Carter AFB & AVS & Edelbrock carbs have shorter float arms which is in part why they are more compact, and smaller floats and they are less tolerant of higher fuel pressures, 6 psi is the max that Edelbrock recommends for their carbs which are copies of the Carter carbs. They recommend that a max pressure used at 5.5 psi. High fuel pressure does not mean more power as many cars we considered as muscle cars used 4-6 psi.
You likely need a decent Fuel Pressure Regulator like Holley's # 12-803 and use a fuel pressure tester in a tee between the carb and FPR to set pressure at 5.5 max. Do not waste money on a Spectre or Mr Gasket FPR. Once set you can remove the tee and tester.
Old May 17, 2014 | 02:41 PM
75 Camper Special
Thanks for the help. I bored & stoked my 460 into a 545 and am trying to figure out what size fuel pump & carb I need
studaddy
Nov 25, 2017 05:28 PM
pickenspolitics
Jan 23, 2014 06:49 PM
Muddominator
Nov 10, 2011 06:39 PM
85f-250-460
Nov 9, 2003 04:10 PM
jvicars4
Aug 1, 2003 12:04 AM
