Wont start hot
Old Feb 10, 2010 | 12:18 PM
RDJ184's Avatar
RDJ184
Wont start hot
2004 6.0 runs great no dtc will not start up after running for awhile let cool down for hours starts right up ..any help would be greatly appriciated
Old Feb 10, 2010 | 12:50 PM
brickie's Avatar
brickie
HPO (high pressure oil) leak somewhere in the engine.It will have to be pressureized to find exactly where the leak is.
Old Feb 10, 2010 | 12:57 PM
jwheatley20's Avatar
jwheatley20
This happened to me 4 wks ago. First, they replaced the dummy plug on the back of the head I believe is what it said? That still didn't work so then they determined there was an o-ring on the HPOP that was leaking. That fixed it. Ill re-type the work order they typed up when they fixed it when I get home.
My symptoms were crank right up... Drive to subway... Turn truck off in the drive thru, then it would just turn over and turn over but not start. Let it sit for 10 min, then it would usually crank. Its embarrassing lol .
Old Feb 10, 2010 | 01:03 PM
RDJ184's Avatar
RDJ184
Thanks guys i have been looking for leaks and cant find any but I am not done yet
Old Feb 10, 2010 | 06:39 PM
jwheatley20
Straight from the work order:
Check and advise on VEH taking a long time to start when engine is warm. Turns over but will not start.
CCC D03 CC D8 Found leaking dummy plug on left bank and STC at HPOP leaking. Hard start when cold is from injectors 2,5,6 sticking when cold even after latest calibration was installed in PCM.
Verified concern. Truck is hard to start when cold and runs rough. After truck warms up idle smooths out, when turned off truck will be hard to start. KOEO PASS KOEC P2291 KOER PASS. PPT Diag and Diesel Diag lead to air pressure test. Air pressure test shows no audible leaks. Removed valve covers and retested. Found O-ring on left bank leaking on dummy plug. Replaced dummy plug and re air tested. Found air leak at STC fitting. Removed HPOP and replaced STC fitting. Retested. Cleared codes Reset KAM and test drove. Retested. After cold soak over night, truck still runs rough when cold and blows white smoke. Power balance indicates cylinders 2,5 & 6 dropping out. Replaced injectors 2,5 & 6 and reprogrammed PCM to latest level. Test drove and retested after cold soak. Repair complete.
Old Feb 10, 2010 | 07:58 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
If its an HPO leak you won't see it- its internal.
q240z
Oct 19, 2017 12:50 AM
Whitey Ford
19
Dec 2, 2015 10:11 AM
white cat
1983 - 2012 Ranger & B-Series
Dec 16, 2013 10:33 AM
jdsunset
May 17, 2012 07:51 PM
JerrywallaceII
Sep 27, 2011 07:06 AM
