having starting problem when hot 72 F150 W/360
I have a 72 F250 Camper Special with a 360with a 2 barrel carb. I have recently purchased it and am having problems starting it up when hot. I have timed and adjusted the carb to spec. I have been playing with the auto choke and it starts great when cold and runs great, but has trouble cranking when hot. Any help with this would be great.
I had an issue with my last 390, heat soak caused me fits and hard restart when hot and sat for a few minutes. It would perc the fuel out and be flooded. I tried different spacers and all kinds of tricks, finally installed a Holley 2 bbl., problem solved
FWIW, not a 72 F-150, no such model.
A $22 carb kit, gallon of solvent, and she was fine again. Yeah, I'd definitely do a carb rebuild to take the carb's'condition out of the equation. If it still happens, then I'd look into heat soaking/vapor lock issues.
Oh, I assume the fuel filter has been changed already...
GeneStoner
12-25-2004 11:41 PM
rbmopar
09-16-2004 12:35 AM
65f100CoryE.
17
12-11-2003 05:43 PM
alanscott
03-13-2001 07:43 AM
