1987 ignition switch
Old Feb 9, 2010 | 04:14 PM
Roy C's Avatar
Roy C
My son is trying to change out the ignition key switch as well as the contact block on our 1987 F150. My understanding is that he should be able to change out both without pulling the steering wheel off. Is that correct?
Old Feb 9, 2010 | 04:31 PM
dembry1's Avatar
dembry1
key switch
if the truck has tilt stewering you can change without removing wheel,if non tilt you will probably have to remove wheel.I have the tilt and it takes just minutes
Old Feb 9, 2010 | 05:22 PM
Roy C's Avatar
Roy C
Dembry1,
Thanks for the info. It does have the non-tilt column. I'll pass the info on to him so he can be looking for a puller. Thanks.....
dyoungen
Dec 24, 2014 09:53 PM
oliver28472
Apr 24, 2013 05:18 PM
cabby02nyy
Oct 20, 2012 06:21 AM
zzjonze
Jun 20, 2007 09:30 PM
bluewolf
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 7, 2003 08:30 PM
