Wont stop turning over
Old Jun 6, 2007 | 07:46 AM
zzjonze's Avatar
zzjonze
Sometimes when I hit the key the truck starts but the starter stays engaged till I get out and peck on the solonoid.
I did put a new solonoid on it yesterday but it still done the same thing.
Has anyone else had this problem with 1987 F150 4.9.
Also I might mention my ignition switch feels like it is a lil stiff and not kicking back after I start the truck.
ZZ
Old Jun 6, 2007 | 07:48 AM
pfogle's Avatar
pfogle
The switch is the problem, not the solenoid. You can try to lube the switch with wd-40, but I think I'd just replace it. It could also be an internal problem in the column.
Old Jun 6, 2007 | 08:02 AM
zzjonze's Avatar
zzjonze
Ok thanks for the info
ZZ
Old Jun 6, 2007 | 01:19 PM
Lazy K's Avatar
Lazy K
You should have a real strong spring return from "start" to "run". The return spring is in the ign./start switch not the key switch. Look under the instrument cluster and on top of the steering column and you will see the it. It is connected to the key switch by a thin rod that runs up the column to the ign. switch actuator which is, in turn, connected to the key switch. Your problem may be a faulty ign./start switch or the ign. switch actuator needs replaced. From your description of no spring return I would look at the ign./start switch first.
Old Jun 7, 2007 | 03:31 PM
zzjonze's Avatar
zzjonze
Ok I took old key switch out and put a new one in. Cleaned it all, oiled, and Put it all back together and it still keeps trying to start not disengaging the starter.
Took starter off and checked and everything there looks fine.
I did see the actuator rod and cleaned it and lubed it the best I could.
How do you take out the ign. switch actuator
Any info on that would be helpful.
Thanks
ZZ
Old Jun 7, 2007 | 09:40 PM
pfogle's Avatar
pfogle
Did you replace the part where the key goes (the ignition tumbler NOT the switch)? Or the actual switch down on the base of the steering column?
Old Jun 20, 2007 | 09:21 PM
bigorr's Avatar
bigorr
I had same problem it appears to be a dead cell in the battery bought new battery have had no problems in my 87
Old Jun 20, 2007 | 09:30 PM
Dean88's Avatar
Dean88
Is your key sticking in the start position? My '87 won't spring back from the start position, so I have to manually move it. It doesn't bother me, but my Ma almost ruined my starter, because she bumped the starter and let go of the key, but the starter just kept spinnin.
woodstockaz
Feb 14, 2017 08:37 PM
8720fordfan
Nov 10, 2012 09:42 PM
250idi
Jan 12, 2011 09:04 PM
StrongRepublican
22
Feb 19, 2007 02:20 PM
ross lanius
Aug 31, 2003 10:13 PM
