Rerouting Plug Wires Cures Stumble
Old Feb 8, 2010 | 01:15 PM
BCHauler's Avatar
BCHauler
Just wanted to post a tip for others who may have similar issues. I've always had a slight hesitation or stumble under load at highway speeds. Truck has run well except for this issue. I just recently rerouted the plug wires taking care to keep them all as far away from each other as possible. The result is that the stumble / hesitation has disappeared and the 351 actually feels like one now when I need it.
Hope this helps.
Old Feb 8, 2010 | 02:55 PM
Eddiec1564's Avatar
Eddiec1564
I have the same issue with my 302, I just need to replace the wires and reroute them, but that stumble sure will drive you crazy looking for it!
Old Feb 8, 2010 | 05:05 PM
Paul T's Avatar
Paul T
You might try misting the wires after dark to see if arcing occurs. Use a water bottle that sprays a mist. When you find arcing either move or replace those wires. I had a slight stumble on my 88 F150 with the 4.9 and it turned out to be the egr.
Old Feb 8, 2010 | 07:59 PM
skyfox10's Avatar
skyfox10
any suggestions on the best way to route these wires?
Old Feb 8, 2010 | 08:07 PM
skyfox10's Avatar
skyfox10
Oh, and pics, post pics!
Old Feb 9, 2010 | 02:09 PM
skyfox10's Avatar
skyfox10
no suggestions at all?
Old Feb 9, 2010 | 02:22 PM
86F150302's Avatar
86F150302
Here is mine.
Old Feb 9, 2010 | 02:32 PM
skyfox10's Avatar
skyfox10
did those spacers come with the msd system?
Old Feb 9, 2010 | 03:11 PM
BCHauler's Avatar
BCHauler
Sorry. I'd post pics but my wife has "misplaced" our digital camera so I can't take any pics right now. I can tell you that I removed most of the wire holders. The back drivers side wire I ran behind the coil. The back passenger's side wire went through the upper manifold. Doesn't look very good but cured my issues. I didn't have a plan, just went at it with the idea of keeping the wires as seperate as possible.
I like that msd cap. Looks much easier to keep the wires apart.
Old Feb 9, 2010 | 03:41 PM
Eddiec1564's Avatar
Eddiec1564
Somewhere on here I seen a Ford diagram that shows proper wire routing... Finaly found some info.
https://www.ford-trucks.com/forums/6...e-routing.html
Old Feb 9, 2010 | 03:54 PM
skyfox10's Avatar
skyfox10
I'm thinking, that I might try taking the extra wire holders that I have on my 1995 (if they are still there) and use them to further space out my wire, (leaving the centers empty)
Old Feb 9, 2010 | 03:55 PM
skyfox10's Avatar
skyfox10
I thought this was kind of interesting. It shows where crossfire is common on certain engines
http://www.jasperengines.com/pdf/Spa...oss-FireTB.pdf
Old Feb 9, 2010 | 05:27 PM
86F150302's Avatar
86F150302
No I bought them from autozone
79lownlong
Dec 6, 2014 05:28 PM
Ddaybc
Aug 7, 2011 11:14 AM
jaye
Feb 13, 2011 08:19 PM
FourbynFord
Nov 9, 2010 05:31 PM
Jason6969
16
Jan 29, 2007 08:15 PM
