Offroad & 4x4
Dana 70 discs
Old Mar 9, 2010 | 10:32 PM
78250crewcab4x4's Avatar
78250crewcab4x4
Originally Posted by alpha/omega
Looks good Phillip.
We were talking earlier about which model 70 you had....
thats a B.
That's good, thanks a lot everybody for the help!
Old Apr 13, 2010 | 10:12 PM
lannondiesel's Avatar
lannondiesel
Can you convert to rear brakes without changing the proportioning valve or the master cylinder?
Old Apr 13, 2010 | 10:39 PM
73 ford guy's Avatar
73 ford guy
from what i've researched the stock proportioning valve keeps a small amount of pressure in the rear brake system because it takes more movement to engage rear brake drums. Now with the discs in the rear if anything I'd just get rid of the valve completely. I had to put on an adjustable prop valve because it would lock up easily but that was with hydroboost, a much more powerfull system. If your running a stock booster you may not have as much of a problem.
ford1986f250hd
May 22, 2017 10:46 AM
78 Ford F150 460
24
Aug 15, 2016 03:52 PM
F-250 restorer
Oct 30, 2010 09:30 AM
castone001
Apr 18, 2009 01:13 AM
f150_514ci
Jan 6, 2006 12:06 AM
