Sponsored by: Real Truck
35's rub...
Old Feb 10, 2010 | 12:41 PM
  #31
JBlrmker's Avatar
JBlrmker
I am getting a cd sent to me from kodak since the version I have doesnt work with windows 7. I am not confused wioth bs. The less bs the more they stick out the more bs the more they are in. But if I had less bs I would think it would rub even more since it sticks out farther therefore when turning the truck say left sharp the drivers side tire would rub even worse. I think I have the correct wheels. Just wide tires and not quite enough lift. The wheel wells are just shy of it clearing. Sometimes it doesnt even rub
If only I could post pictures....
  #32
JBlrmker's Avatar
JBlrmker
Once I get a new damn camera I will post pics
Old Feb 10, 2010 | 02:08 PM
  #33
Firekite's Avatar
Firekite
Sounds like you've got it figured out. And yeah, based on your description, you're completely right about the backspacing.
Old Feb 10, 2010 | 07:00 PM
  #34
MobeyDick's Avatar
MobeyDick
Originally Posted by texastech_diesel
I tried to get you to tell us about your lift in the last leveling kit threat I saw you in, so I'll ask again. What kind of kit did you use, and how did you fix the radius arm and trac bar issues that come with an 8" lift?
I didn't see it. It's an 8" Fab-Tech, I wouldn't recommend it. Stock Rad. arms Stock Track Bar. I didn't use the Track bar lowering bracket from Fab-Tech. I had one from Superlift that actually dropped the position 8" instead of the 6" the Fab-Tech bracket did. I haven't had any Issues with the Rad arms. The kit comes with rear lowering brackets. I didn't even need an alignment, I've put 40,000 miles on it and tire wear is as good or better then stock. I used Pro Comp (Traction Bars) on the rear.
Old Feb 10, 2010 | 11:53 PM
  #35
Firekite's Avatar
Firekite
I just wish good lifts weren't so damn expensive for the SuperDuty line. Makes all but the most over the top Jeep lifts look like peanuts.
Old Feb 11, 2010 | 12:03 AM
  #36
cartmanea's Avatar
cartmanea
Look at the size of the components side by side and the SuperDuty lifts make the Jeep stuff look like peanuts
Old Feb 15, 2010 | 12:03 PM
  #37
zcg10403's Avatar
zcg10403
hi,
i sorta have the same question except im wondering how big of a tire i can go before i do rub.
i have an 05 2wd f150 with 3in levelinh kit. idk if 33's will look big enough so im leaning towards 35;s
does anyone know if they'll rub??
Old Feb 15, 2010 | 02:59 PM
  #38
cartmanea's Avatar
cartmanea
Don't know about an F150, this is a SuperDuty forum.
Old Feb 15, 2010 | 07:04 PM
  #39
Nathan6.8's Avatar
Nathan6.8
not sure if 35s would fit your truck but 33s look big enough on f150s even with a 3 inch lift. Plus you have a 2wd so it should not be as high as a 4wd with 3inches
Old Feb 16, 2010 | 12:00 AM
  #40
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Originally Posted by zcg10403
hi,
I know this is the wrong section, but I just lifted an 06 2wd F150 about two months ago so I'll play.
265/70-17s are roughly 31.5" tall and fill up the wells about like a stock 4wd would after a 2.5" lift using 8" wide wheels with a pretty shallow offset. 33s are the biggest you need to be looking at, 35s would IMO be a bad call for a few reasons. One is I have a 250 with a 2" lift and 35s and I can feel a low end power loss with a PSD. If you have anything less than the 5.4L, a regear will be a must with 35s, and recommended with 33s. Secondly, you'll be putting a lot of stress on the front components. Your tie rods and upper ball joints are well, small. You can stuff the tires in there, but your front end will wear out a lot sooner. Plus you have a 2wd, it's not like you need the 35s for anything practical, so stay with a smaller tire.
XolieX
6.7L Power Stroke Diesel
May 22, 2017 04:17 PM
MyhreeMotors
Sep 12, 2012 05:47 AM
Lloydable
Feb 17, 2012 01:23 PM
lucaslaw
Nov 9, 2010 05:01 PM
landon460
1978 - 1996 Big Bronco
Apr 6, 2009 09:21 PM
