Headlight replacement!! Help!
Old Feb 8, 2010 | 09:00 PM
Krisx125's Avatar
Krisx125
Just bought replacement headlights from ebay. Took a quick look at them, and it seems pretty labor intensive to install...has anyone done them? Any tricks? Thanks guys!
Old Feb 8, 2010 | 09:16 PM
fordpride's Avatar
fordpride
lots of fun LOL you got to remove both battery tray to get to 2 10mm nuts on each side at bottom behind park light and two screws on top of each light door (trim) and there is some locks on each adjustment screw that has to be removed
Old Feb 8, 2010 | 09:23 PM
donbrown's Avatar
donbrown
IS there a place where we can see a step by step guide?
Old Feb 8, 2010 | 09:30 PM
Krisx125's Avatar
Krisx125
Ohh joy! this will be fun LOL ^^^ is there a guide?
Old Feb 8, 2010 | 11:30 PM
foxracing0934's Avatar
foxracing0934
Kris..... hate to tell you this but have fun... lol. I know that there is a pretty good write up for this swap but I can't find it at the moment, I'll keep looking at post up if I find it.
Old Feb 8, 2010 | 11:37 PM
wheelie31's Avatar
wheelie31
i bought a whole new header panel grill and headlight set on ebay and you Dont need to remove the battery trays just the batterys, I put my complete setup on in 2 hours, but thats the whole header panel which is the hardest part, Just to do the headlights should be maybe 30min to an hour all depends on how quick you are with a wrench, Its pretty much the 2 10mm bolts and the philips screws that go into the header panel.
Old Feb 8, 2010 | 11:59 PM
foxracing0934
Well the site that had the best write up out there no longer has it because of a dispute between members haha figures. But here is the site if you want to try and see if they got it back http://www.olderfseries.net/ and i also searched it on here and this is where i originally found that write up https://www.ford-trucks.com/forums/7...-assembly.html. Hope this helps
Old Feb 9, 2010 | 08:01 AM
Action4478's Avatar
Action4478
This is all we have for now :
Old Feb 9, 2010 | 08:21 AM
Neal 97 250's Avatar
Neal 97 250
Rick is right. Just two screws on top and two nuts on back lower.
The nuts are the hardest to get to because of the limited room. Removing the batteries will make it much easier although I have done one of mine with the battery still in but dropped the nut when reinstalling.
I would recommend removing the batteries.
