Sponsored by: Real Truck
7.3 LEAK HELP
Old Feb 9, 2010 | 09:03 AM
superduty4x4's Avatar
superduty4x4
Originally Posted by F350-6
(Diesel can mix with engine sludge and look like an oil leak).
Did someone say engine sludge?
The turbo pedestal O-rings are also a common source of leaks that you should check out. You will probably want to wash the motor down first to help find the leak, or go buy some of that fancy dye and a black light to help you find it.
Old Feb 11, 2010 | 11:53 PM
nonyabiztoo's Avatar
nonyabiztoo
If you find it's diesel, my '99 leaked out of the water drain valve behind and under the fuel filter that's on top of the engine. A new valve was cheap, 6 or 8 bucks, and did the trick! Good luck!
Old Feb 12, 2010 | 06:29 AM
hammer65's Avatar
hammer65
7.3 Leak
Originally Posted by kdfishe43
and just in case it is the o rings can anyone tell me what size they are?
Check this out/
Replacement O-rings for Ford Diesel Engines
srkr
6.7L Power Stroke Diesel
Apr 10, 2011 07:09 PM
kdfishe43
Feb 9, 2010 03:33 PM
a-rod
31
Jan 11, 2008 07:49 PM
mowryj
Jan 4, 2008 07:47 PM
zontral
Jul 7, 2006 08:03 AM
