locking hubs
Old Feb 8, 2010 | 09:13 AM
mattpowerstroker's Avatar
mattpowerstroker
locking hubs
im sure this has been asked before but i cant find it...does it hurt our trucks to run with the hubs locked in for days on in...with all the snow we are having on the east cost and from going from dry roads to snow coverd i have been just leaving them locked.. so i didnt know if it would damage anything..
Old Feb 8, 2010 | 09:16 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Many guys on here do just that. Lock them in in the fall and unlock them in the spring. Might see a little lower MPG.
Old Feb 8, 2010 | 09:18 AM
DieselCamper01's Avatar
DieselCamper01
What Rick said
Old Feb 8, 2010 | 09:20 AM
mattpowerstroker
thanks guys for the quick response
Ponyboychris's Avatar
Ponyboychris
Not an issue at all leaving them locked. I sometimes forget but it won't harm anything.
Old Feb 8, 2010 | 09:52 AM
rebelchevy02's Avatar
rebelchevy02
Just dont leave one side locked in, and the other side not locked in. You can potentially destroy your spider gears. When one side is in, and the other side isnt, the only thing typically spinning is the spider gears. But the ring gear isnt slinging any oil. While the oil level should be right near the bottom of the spider gears, that just isnt always the case. So you end up having your gears spinning, with little to no oil. Some people get away with it, and I suppose you could decrease chance of failure, if you managed to over fill your diff, providing oil to the spiders without slinging. But running them with both sides locked in is fine, just could hurt some mpgs.
andybear5014
Dec 4, 2013 06:58 PM
jts140
Jan 1, 2013 11:49 AM
Molineguy
Feb 2, 2011 01:46 PM
MonatheGrona94
Mar 19, 2009 11:42 AM
HarryD001
Nebraska Chapter
25
Mar 21, 2006 12:39 PM
