Please explain locking hubs
Old Dec 30, 2012 | 07:57 PM
jts140's Avatar
jts140
Up here in PA from FL. Driveway were I am staying has a lot of snow and angle. For some reason truck would not go into 4x4 with switch, maybe cold affected it, never happened in Fl. So I manually locked front hubs, if I use switch to go to 2wd with hubs still locked what would happen. Have to pull out in morning with trailer loaded and was curious. Never had a vehicle with manual locking.
Old Dec 30, 2012 | 08:01 PM
2006lariat's Avatar
2006lariat
You can run with the hubs locked. Once you get out of the snowy area, if headed back to Florida, unlock them when the weather/roads permit. It won't hurt them being locked.
Chances are you got condesation(that froze) in your 4X4 vac system, or a leak, and that is why your auto function isn't working.
Old Dec 30, 2012 | 09:59 PM
AzSuperDuty's Avatar
AzSuperDuty
In winter weather as you describe it is always best to manually lock your hubs in before it gets bad. Otherwise you could find they freeze in the unlocked position and you can't lock them by switch or by hand.
Old Dec 30, 2012 | 11:04 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
leave them locked and switch in and out as you need. it will only hurt your MPG's. once you get out of the area unlock them. easy as pie
Old Dec 31, 2012 | 10:15 AM
Ironhide's Avatar
Ironhide
Your post makes me think that you don't normally get out and lock your hubs when you switch to 4 wheel drive. You do realize that while the switch on the engages the transfer case, if you have manual locking hubs, you will NEVER actually be in four wheel drive UNLESS you get out of your truck and lock the hubs. If you believe that you are going to be in a situation that requires the use of 4 wheel drive it is fine to lock the hubs and drive, just means that the front axle and drive shaft will turn, but the transfer will not be engaged until you flip the switch. Just as if you flip the switch without locking the hubs, the transfer will engaged the front drive shaft and axle, but the axles will spin freely in hubs, unless the hubs are locked.
Old Dec 31, 2012 | 10:50 AM
AzSuperDuty
Depends on how the truck is equipped. My hubs have an AUTO position and a LOCK position. Auto they lock up when the switch in the cab is used to select 4WD. LOCK position (Manually engaged) they stay locked all the time regardless of the switch position in the cab.
In winter weather where the possibility of moisture and freezing it is wise to manually engage the hubs and leave them so until the weather improves. Much the same as one would be ill advised to use the parking brake in freezing/wet weather. (been there, done that, learned my lesson)
Old Dec 31, 2012 | 10:56 AM
Ironhide's Avatar
Ironhide
Good call, the thought of "auto" and "lock" didn't cross my mind, I am so used to "free" and "lock" being the option on the hub. Thanks for setting me straight.
Old Dec 31, 2012 | 11:32 AM
AzSuperDuty
HA.. you think this is something. I have a 99 Explorer that is AWD. A fact that initially escaped me. I have a three way switch on the dash that says 4X4 and under it AWD - High - Low.
It is in AWD as the norm. Front axle takes up pulling when the rear wheels slip.
High locks the transfer case and the front axle pulls all the time regardless of rear wheel slippage. Low is low.
I was chasing a rumbling noise in my rear end. Didn't know if I had bad wheel bearings or a problem in the differential. (turned out to be bad pinion bearing) In the process I was going to put the rear end up on jack stands, the truck in gear and and then crawl around while it was running and see where the sound came from. Fortunately I had an epiphany just before getting the thing up on jack stands!
Cause if I'd a done what I planned, I'd put that thing in gear, AWD front end would have said..."Them rear wheels are a slipping" and the whole mess would have come crashing down right after I moved the gear selector.
Somedays lady luck smiles on me!
Old Jan 1, 2013 | 11:49 AM
jts140's Avatar
jts140
Thanks for replays. My hubs do say auto and manual
openexcess
May 27, 2011 10:42 PM
MacGSX
Feb 26, 2011 12:21 PM
Pinky Demon
Sep 30, 2008 08:34 PM
Flywest
Jan 30, 2007 07:38 AM
ZPULLR
Dec 18, 2002 09:31 AM
