4 Wheel drive help
Old Feb 15, 2010 | 04:10 PM
  #46
RussB's Avatar
RussB
Originally Posted by robles4242
I believe i found the right parts.
Spline count: 30
Premium Hubs part number: 38826
Standard Hubs part number: 11690
Can anyone verify them before I make a purchase. Thank you.
Trying to find out for you ! Bare with me.
Old Feb 15, 2010 | 04:14 PM
  #47
RussB's Avatar
RussB
38826 premium hubs are the one that I put in my 2003 truck and my buddies 1999. I just looked it up on my bill of sale !
Old Feb 15, 2010 | 04:43 PM
  #48
robles4242's Avatar
robles4242
So i can get away with just buying the hubs? Someone said conversion kit needed but you guys say I can bypass it by cutting a vaccum line and jamming it shut with a screw and rtv around it?
Old Feb 15, 2010 | 04:47 PM
  #49
RussB's Avatar
RussB
I did not use any kind of a conversion kit ! Jammed a screw in it and carried on. Had them in there since 08 and haven't had a problem with my 4WD since.
Old Feb 15, 2010 | 04:56 PM
  #50
spdmpo's Avatar
spdmpo
Put these on:
Amazon.com: Warn 38826 Premium Manual Hub Kit: Automotive
Then just unplug the line at the vacuum pump and cap the port. No need for screws or anything else. Leave the lines hooked up at the knuckles to keep dirt etc out of it.
Old Feb 15, 2010 | 04:59 PM
  #51
RussB's Avatar
RussB
YA... what he said !
I put in a plug at the knuckle and plugged the hose... both works... That way might be a bit cleaner though !!
Old Feb 15, 2010 | 05:04 PM
  #52
robles4242's Avatar
robles4242
Well I ordered Warns Standard hubs #11690 for $179 from Napa. It will be in tomorrow around 1 PM.
Old Feb 15, 2010 | 05:11 PM
  #53
robles4242's Avatar
robles4242
What am i using to cap it with lol bubble gum?
Old Feb 15, 2010 | 05:18 PM
  #54
RussB's Avatar
RussB
Thats not the one I used... so can't help ya there... Hope they are fine !
Old Feb 15, 2010 | 05:29 PM
  #55
robles4242's Avatar
robles4242
You used the good expensive premium ones. I just ordered the standard ones. Thats the only difference everything else is the same. Dana 60 with 30 spline.
Old Feb 15, 2010 | 06:26 PM
  #56
RussB's Avatar
RussB
Sounds good ! Good luck with the install ! Hopefully you'll have 4WD after they're in !
Old Feb 15, 2010 | 07:40 PM
  #57
spdmpo's Avatar
spdmpo
Just use a vacuum cap, napa will have them.
Old Feb 15, 2010 | 10:39 PM
  #58
robles4242's Avatar
robles4242
*Deleted Message*
Old Feb 16, 2010 | 09:47 AM
  #59
robles4242's Avatar
robles4242
Any idea on what size the Vacuum line is so I know what size caps to get?
Old Feb 16, 2010 | 10:47 AM
  #60
spdmpo's Avatar
spdmpo
Just get a pack with assorted sizes, they'll look like this:
Amazon.com: Vacuum Caps Incl. Four Each 1/8/3/16/0.25/5/16/3/8 in.: Automotive
Don't get the black rubber ones, they crack and degrade easily.
