Well i had my girlfriend turn the 4x4 **** while i was under and i could hear it engage. When your talking about turning the driveshaft test do i have to have the front end of my truck jacked up off the ground?
no it has to be on the ground so that the wheels on the pavement stop the driveshaft from turning(that is, if its engaging the driveshaft).
OK... so the switch and the transfer case is all good ! Turn the hubs in manually and see if you can turn the big u-joint that is behind the wheel ! If you can still turn those with your truck in 4WD then your hubs are screwed. If those u-joints can't be turned and it is locking in the hub manually then I would say you have a vaccum leak and your auto part of the hub is not working ! Make sense ???????
Awesome! I'm going to go try it right now! I'm hoping that it is the hub and ill just swap them out for a good set and be good to go!! Ill reply as soon as I try!
I was at a local parts dealer today and they found a set of WARN hubs in the computer then another guy that works there said I COULDNT replace them with aftermarkets or anything because of a vaccum line. What am I supposed to do Its bad weather here and i need 4 wheen drive bad.
I trust you guys over any random joe! What am i supposed to do, is there after market hubs available?? Where can i get them from? If i try to rebuild from guzzles post is that the right part number for a 2000? I know he has a 2002! Please help! Im going nuts!!
Yes you can put Warn hubs in..... I've got them in my truck !!!!! You have to cut and plug the vacc lines where they enter the wheel well ! Right where the steel line turns into rubber. Cut the rubber hose and jam a screw in it with a bunch of RTV on it ! By by vacuum leaks and hello 4WD
U can. Go to warns website and they have you enter in ur vehicle info and show u your options. there are some restrictions on some models but once ur on the website ull know whats up. If for some reason your truck is in the group of exceptions and u absolutely need ur 4x4, use guzzle's instructions and try cleanin them out
