Door jam #,s
warranty # = F26CR481824
W.B. = 120
COLOR = J
MODEL = F 260
BODY = EB 1
TRANS = F
AXLE = B 4
MAX GVW LBS = 6800
NET H.P. = 135
RPM = 3800
DSO = 72
Thanks again Rod
Your VIN number: F26CR481824
Your Model Year is November 1963.
Truck Series: F250 4 Wheel Drive
Engine: 2V - 292cid, 135 HP, 3800 RPM
Assembly on: San Jose, CA
here's some more:
W.B. = 120
COLOR = J =Rangoon Red
MODEL = F 260
BODY = EB 1 =Conventional Cab
TRANS = F =4-speed Syn. Warner (T18)
AXLE = B 4 =4.10 - Dana 60 (5,200-lb)
MAX GVW LBS = 6800
NET H.P. = 135
RPM = 3800
DSO = 72
I don't know what engine code 'C' stands for, but it could be a 292. HTH.
Will
W.B. = 120
MODEL = F 260
MAX GVW LBS = 6800
NET H.P. = 135
RPM = 3800
DSO = 72
FTE VIN decoders are next to worthless, have all sorts of errors and omissions.Here's the correct info from the parts catalog.
F26 = F250 4WD
C = 292 2V
R = San Jose CA Assembly Plant
481824 = 1964, assembled December 1963 (December 1963 serial number range: 480,000 thru 489,999)
120" Wheelbase
J = Rangoon Red
F260 = F250 4WD / 6800 lbs. GVWR
EB1 is actually E81: E = Red Crush Vinyl & Red Check Stripe Woven Plastic // 81 = 81B Custom Cab
F = Borg Warner T-98 4 Speed Manual Transmission
B4 = Spicer-Dana 60 / 4.10-1 / Limited Slip / 5200 lb. Rear Axle Capacity
6800 lbs. Gross Vehicle Weight Rating
135 net HP @ 3,800 RPM
72 = San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
Ford usually did not include the front axle code within the Warranty Plate AXLE code.
2) B9TZ1190A .. Front Wheel Grease Seal / Obsolete // Dana part number: 34611
Fits: 1959/68 F250 4WD Dana 44 / 1969 F250 4WD Dana 44 before serial number F30,001.
2) B9TZ3254A .. Front Driving Axle Shaft Seal / Obsolete // Dana part number: 17478-A
Fits: 1959/72 F250 4WD Dana 44.
D4TZ3132A replaced B9C3132A .. Spindle Arm Seal Kit / Obsolete // Dana part number: 706207 X
Fits: 1959/74 F250 Dana 44.
