8 lug conversion
Old Feb 25, 2009 | 08:32 AM
OrFordGuy's Avatar
OrFordGuy
8 lug conversion
I'm parting out a 78 f250 and want to use the axles to streghten my bronco. Dana 60 rear swap i get, but what parts off the front do i need? knuckles, axles, brakes? The front axle on both are 44s, leaf and coil accordingly.
Old Feb 25, 2009 | 08:43 AM
teds74ford's Avatar
teds74ford
Bronco knuckles and axle shafts. 250 spindle, brakes, 8 lug hubs. The lockouts are the same.
Old Mar 4, 2009 | 02:23 AM
OrFordGuy's Avatar
OrFordGuy
8 lug
Thanks, a buddy says the shafts need the short shaft swapped out. Can you confirm or deny this?
Old Mar 4, 2009 | 08:24 AM
teds74ford's Avatar
teds74ford
I used 150 shafts from the pumpkin out. I am assuming you really do have 78 F250 parts, and not the older ones with the huge lockouts. I don't know about parts interchange with the big lockouts.
Old Mar 4, 2009 | 02:15 PM
m j's Avatar
m j
the bronco shafts work with the f250 outers
have a bronco here with 78/9 f250 outers, no issues in regards to fitment
the chromo Yukon shafts for a F150/bronco dropped right in when it came time to upgrade as well
Old Mar 4, 2009 | 10:14 PM
OrFordGuy's Avatar
OrFordGuy
8 lug swap
Thanks guys it is a 78 with the smaller lock outs. All my trrucks are 78-79 except the 77 f150 4X2. I am however contimplating a Wagoneer/Bronco rockcrawler/offroad buggy and a custom 71/72 4x4 project if I can find the reasonalbe and local.
Old Mar 5, 2009 | 06:36 AM
teds74ford's Avatar
teds74ford
Might consider replacing the shaft u-joints while you have it apart. I didn't, and tore it back apart pretty shortly after I had just put it back together.
Gene Horr
Oct 3, 2014 12:41 PM
ballbandit
Dec 16, 2011 06:49 AM
mando jake
Jul 25, 2007 04:57 PM
4xfordman
Feb 9, 2002 11:24 PM
