V10 owners step inside (supercharger project)
I've always been into supercharging things to get the best performance out of them. From Vortech mustangs to procharged corvettes. That was until I got my V10 excursion. Didn't want a centrifical because I wanted lowend torque for towing. The two companies that offered root type blowers no longer make them and no one has a turbo kit. So I set out to make my own kit. A V10 is just a 5.4L with two extra cylinders. So why not take the supercharger off of a lightning and modify it to work on a V10?
PLAN:
Take two lightning lower intakes and cut them in half and join them back together to make a intake for the V10. Not only would it make good power but parts are plentiful for the lightnings. This could easily be done for under $2,500 with used lightning parts.
I have gathered most of the parts for this and should start on cutting the intakes up in a week or two. I will be posting pictures as I go along. This build is also in the V10 engine section incase you don't make it over there.
PLAN:
I picked up the engine off of craigslist for $150. Some old guy bought it for a street rod and couldn't figure it out, lol.
curious what your going to do about a serpentine belt.
but compared to the rest of the project that will be pretty minor i suppose, haahah
def. looking forward to watching the results.
do you have plans to add higher performance parts to the V10's bottom end ? i hear the V10 with stock parts isnt able to handle being Turbo/Supercharged for long.
The stock bottom end should handle 8psi no problems. It will be intercooled which 80% of the supercharger kits on the market are not. I had a 5.4L expedition with a procharger running 9psi with no problems for 30k miles. They share the same piston and rods so with a good tune it will live.
He's a picture of the heat exchanger and water pump.
Subscribing, even though I'm a V8 owner. I accidentally tripped and fell into this thread
I'm just anxious to see you start cutting up those intakes!
Ooops, I too tripped and fell into this thread. I have a feeling I'm going to be tripping and falling a lot of times within the next few weeks. Best of luck, I'm sure it will be a very exciting and rewarding project. I'm getting a headache just thinking about attempting it myself.. haha, don't think so. Keep us updated... uuuhh, I mean, the V10 guys, I'll just see it on my way down.
Good luck, maybe when your done tackle a 5.4????
