V10 owners step inside (supercharger project)
ummm how are you going to go about tuning the airflow performance of the additional 2 intake runners you need to graft on ???
seems to me each intake runner must be tuned perfectly or your going to have some cylinders making more power then others, which could spell death for your motor..
but GL on it, certainly interested to see the outcome.
This might be plain crazy but didn't Ford make a supercharger for the Hydrogen fueled 3 Valve V10? I think they were for small Bus type units and generators. If they did, could you not source the manifold from them. They may have more parts that will help out as well. The trick is finding out who to talk to as I don't know if they include "green products" in the performance dictionary...
Just a thought that might help a cool project...
JL
You guys with 2V 6.8L engines may want to look at this. (Yes, it is a Paxton blower, not a roots style)
PAXTON NOVI 2000 FORD V10 SUPERCHARGER KIT 6.8 LITER | eBay
I've always been into supercharging things to get the best performance out of them. From Vortech mustangs to procharged corvettes. That was until I got my V10 excursion. Didn't want a centrifical because I wanted lowend torque for towing. The two companies that offered root type blowers no longer make them and no one has a turbo kit. So I set out to make my own kit. A V10 is just a 5.4L with two extra cylinders. So why not take the supercharger off of a lightning and modify it to work on a V10?
PLAN:
Take two lightning lower intakes and cut them in half and join them back together to make a intake for the V10. Not only would it make good power but parts are plentiful for the lightnings. This could easily be done for under $2,500 with used lightning parts.
I have gathered most of the parts for this and should start on cutting the intakes up in a week or two. I will be posting pictures as I go along. This build is also in the V10 engine section incase you don't make it over there.
PLAN:
my name is Jacek and I'm from Poland and I done more or less the same
I have ford F350, V10, 6,8L, 2001
but...and I have a big problem here in Poland - I put this truck Eaton supercharger from Mustang Shelby GT 500
my question is - can You help me with programming my PCM for driving my car, I want to changed injectors also
or.......do You have wiring diagram of PCM my ford truck ?
maybe I can send my PCM to You and You will upgread my computer to have the best results of my engine with supercharger
please let me know as soon as possible
best regards
Jacek
p.s.
maybe You will know some company witch can help me with this - please
#29
Jason Byars
10-18-2016 08:46 AM
