Modular V10 (6.8l)
tune up help
Old Feb 4, 2010 | 08:21 AM
terryswafford's Avatar
terryswafford
tune up help
I have a 2000 F350 V10 with 70,000 miles. The truck has never been tuned up. Im not a macanach but I would like to do as much of the tune up as a can. I dont have any mods and have stock tires. My question is what do I need to change or replace. I know there is a lot of brands out there of different parts but I was hoping some one could make it simple for me and give me a list of what to buy. Thanks very much for any help.
Old Feb 4, 2010 | 08:48 AM
dkf's Avatar
dkf
Replace plugs with OE spec Motorcraft plugs, replace COP boots, clean MAF (CRC MAF cleaner available at most parts stores), replace fuel filter, clean or replace air filter, good idea to replace PCV valve, clean throttle body. Just some things off the top of my head. Motorcraft replacement parts are good and for the ignition components, filters and etc are worth paying for. I do use Napa gold fuel filters though, they are a quality US made filter. Would be a good idea to inspect belts, hoses and vaccum lines while under the hood. The tensioner pully bearing for the serpentine belt is probably dry and rough by now.
Old Feb 5, 2010 | 11:07 AM
TeamMudd's Avatar
TeamMudd
Good maintenance info, here's some part numbers for you to go off of too.
Plugs : auto lite 103's (factory ford equivalent)
Fuel filter : NAPA 3296
Oil filter : NAPA 1372
cleaning the MAF, get you a good "contact circuit board cleaner" that leaves no residue. that's the biggest thing, it can't leave any residue on the little wires. some people have said to take a q-tip and "lightly" clean the wires. i personally use the contact cleaner and the red tube and haven't had a problem. you might be able to clean the throttle body with it still attached, some good parts cleaner or degreaser will do the trick.
Old Feb 11, 2010 | 12:43 AM
terryswafford
Thanks for the info guys. One more Question, Do I have to have a special tool to get the fuel filter off ?
Old Feb 11, 2010 | 09:05 AM
terryswafford
Anyone know the answer to this ? Thanks
Old Feb 11, 2010 | 10:44 AM
TeamMudd's Avatar
TeamMudd
yes. the fuel filter needs a disconnect tool similar to one like this.
Amazon.com: 5/16 In Fuel Line / Filter Disconnect Tool - Ford: Automotive
5/16 disconnect tool. if you have a harbor freight, or similar type store around they have a whole kit (4 or 5 tools) for around $10. if you catch a sale you can usually get them for cheaper.
but any of your local parts stores should have one for you.
beemr
Jan 31, 2014 11:29 AM
emmagator
Sep 12, 2007 09:11 AM
BURNSTOUGHFORD
1997 - 2003 F150
Mar 19, 2007 09:04 AM
Onespeed24
Computer Chips & Tuners
26
Jan 11, 2006 07:12 AM
FTE Ken
Jan 25, 2005 10:58 AM
