ccv mod
Old Feb 2, 2010 | 09:17 PM
funzjb1's Avatar
funzjb1
ccv mod
I am looking to put an 6.0 intercooler on my 96' 7.3. my question is do i need to do the CCV mod to put on the intercooler? If yes, why? or is this just a good mod to do anyway? What exactly is the mod.?
I am still trying to round up the intercooler parts. Will a intercooler off a 2006 work and just get different pipes?
Old Feb 2, 2010 | 09:51 PM
KonaGrown's Avatar
KonaGrown
I know that if you don't do the CCV mod when you have an intercooler then you could blow off the intercooler boots with the oil that gets into the intake. Others might chime in with a little more info.
Old Feb 3, 2010 | 12:54 AM
JamesHajek's Avatar
JamesHajek
I believe you can use and 7.3 or 6.0 intercooler but the only spider that will work is from an early 99 cuz of the way it fits to our trucks. And there are a couple good threads on here for the ccv mod. Basically you turn around the doghouse attached to the valve cover and run like 3/4" hose towards to the back of the truck to get the oily mist routed away from the intake and the turbo.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Feb 3, 2010 | 12:57 AM
JamesHajek's Avatar
JamesHajek
Here's a good thread. It should help you. It is very simple.
https://www.ford-trucks.com/forums/858361-ccv-mod.html
ultrasks700
May 9, 2014 06:04 AM
91 Dually
Apr 15, 2014 04:59 AM
surveyguy
Apr 20, 2009 01:14 PM
Ford79
Apr 28, 2007 08:22 AM
John7894
24
Feb 24, 2006 07:54 AM
