Is it possible to clean the inside of the intercooler???
Guys,
My truck has 230K on it. It's an 01 and I just bought it a few weeks back. The boots and connections on the intake piping are all oily. I did the typical searching and found that this is due to the CCV that is piped into the intake.
I plan to do the CCV mod. Can I take the tubing/piping and intercooler off the truck and clean it out? Maybe with some Simple Green and a hose? Or will it clean itself out over time?
I'm just concerned that it may be really clogged or partially clogged and affecting the performance of the truck.
Thanks.
Thanks.
I wouldn't right away. First I would clean the engine. Remove all of the intercooler boots and Y-pipe boots and clean them up with soap and water. Make sure that the oil has not begun to attack the rubber which would allow them to crack. If they are bad, get a new set (not cheap). Replace the boots and make sure that all the CT clamps are very square with the tubes, not cocked. Do the CCV mod to keep any more oil out of there and keep a watch on the boots. If they appear to begin getting oily after the CCV mod, then think about pulling the intercooler.
Don't just clean your intercooler - do it right. Take it to a radiator shop and have them clean it out. They'll probably do a better job than you can do - PLUS you can have them pressure test the intercooler and fix all the little air leaks. I've heard that most factory intercoolers suffer from minor air leaks. You won't pick up a lot of boost, but why give away even a little?
Between the improved efficiency from being clean and possible recovery of a little boost, I'll bet your mule will run noticeably better. I'm getting set to do that very thing in April or May - well, almost. I'm going to pull off my radiator and intercooler, replace the intercooler with a cleaned and sealed 6.0L intercooler, and put a Tru-Cool trans cooler in. I have the 6.0L intercooler (it goes to the radiator shop next week) but still need to get the trans cooler.
From what I saw when I cleaned mine, it's not worth the hassle of taking it out. I think I had ~65,000 miles when I cleaned mine and there was very little oil that came out of it. I had really expected to see a lot, but was definitely disappointed.
I used to work in a radiator shop and we used to get in air coolers off the big rigs when the turbo blew that were full of oil. We just poured in a degreaser and let it soak for a while and rinsed it out with hot water from a hot water/ high pressure hose. Then we'd pressure test it for leaks.
I wuold agree with nhancock. I had 125K on mine without CCV mod, and it didn't even manage to discolor the MEK (solvent).
It might be a better idea to get a radiator shop to put a removable plug in the lowest corner of the intercooler. I use plugs on the other vehicle for cleaning purposes.
Originally Posted by arninetyes
...........I have the 6.0L intercooler (it goes to the radiator shop next week) but still need to get the trans cooler.
Thanks guzzle, I'll do everything but the intercooler and keep an eye on it.
Originally Posted by John7894
What's up with using the 6.0 intercooler?! Is it larger/better??.
No special adapters to make.
http://www.longislandperformancedies...0-%20Turbo.htm
Nut
Who...what...me? MEK? the lizzard wearing the tophat told me to do it.
I have used MEK on intercoolers for years without issue. I do know that MEK is slightly caustic and will "soak" into untreated aluminum. I suppose I should have metioned that I rinse with HOT water and DISHSOAP.
I appreciate your concern for my health, but the orderly's here at Ford's House of Perpetual Modifications Disease have it covered. (in the form of my credit card!)
Got one better for you.
get a can of brakekleen or carb cleaner and spray away the buildup. I make a habbit of doing this before I spray the engine down for spring cleaning. Works great.
To answer your question, I would not wipe down the outside of the intercooler with MEK. Nor would I want it anywhere near the silicone boots. I have a regiment of cleaning intercoolers with MEK because I do not want straight water in the intercooler in any application. If I had a day or two to be without one, then I might just use water. MEK is just nasty stuff.
Be sure if you use it to do it in a VERY well ventilated area. No sparks, fire, or heat sources of any kind. A respirator is recomended if you are spraying. Use goggles with periferal protection.
But, still wondering what MEK does to aluminum. I know not to use it, but why? I'm just always wanting to know more, why, how ... "just because" has never been enough for me.
