NOOOO Lights...
Old Feb 2, 2010 | 07:08 PM
N V US Lawn Care's Avatar
N V US Lawn Care
Cool NOOOO Lights...
OK, so here's the deal...I got pulled last night in Ohio because I have no running lights...i also have no dash lights...but, my turn signals and brake lights work just fine...also, my trailer connector burnt in half...i'm figuring i have some major electrical gremlin thing going on...
I checked all the fuses in the fuse panel, and none were blown...so, calling my FTE brothers out again...any ideas???
Old Feb 2, 2010 | 07:14 PM
zx250's Avatar
zx250
Of the next Riffraff East
Were you towing when the trailer wires burned?
Old Feb 2, 2010 | 07:15 PM
zx250's Avatar
zx250
Don't forget you have more fuses under the hood...
Old Feb 2, 2010 | 07:22 PM
N V US Lawn Care
Well, no...i was actually on my way to Fall Branch, TN yesterday morning @ 5am and all of a sudden the dash lights went out...that was all i noticed then, but it turns out that when they went out, i lost everything else too...
Do I really??? I had no idear...lol...it seemed like the problem was some kind of super fuse, not one of those whimpy blade fuses under the steering wheel...lol...i can't imagine all those lights working off of one dang fuse, but i guess anything's possible...i'll go check in the am...
Thanks Barry...
Old Feb 2, 2010 | 07:28 PM
zx250's Avatar
zx250
yep, up to 2001 we had some under the hood as well Here's a link to get you an owners manual. If it don't list a 250, just use 350.
https://www.fleet.ford.com/maintenan...ls/default.asp
rckrwlr's Avatar
rckrwlr
I had the same issue when my old trailers wire harness shorted out. it was a couple of years ago. But I rember having to replace 2 fuses in the engine compartment.
Old Feb 2, 2010 | 07:33 PM
N V US Lawn Care
Thanks for the link Barry...downloading as i type...lol
I hope it's that simple...
Old Feb 2, 2010 | 07:34 PM
4inchlovin's Avatar
4inchlovin
had the same problem should be #8 under the hood should be a 15amp...
That one blows when you short out trailer wiring... and license plate wiring...
https://www.ford-trucks.com/forums/9...wing-fuse.html
Old Feb 2, 2010 | 07:36 PM
zx250's Avatar
zx250
Be sure and fix your short before you start replacing fuses. And hang on to that owners manual. :-)
Old Feb 2, 2010 | 07:41 PM
spdmpo's Avatar
spdmpo
Funny how few people know that the instrument cluster lights are purposely tied in to the running light circuit to make you aware there's a problem. Did you check the maxi-fuses under the hood?
Old Feb 2, 2010 | 07:45 PM
zx250's Avatar
zx250
Tow enough things long enough and you will find out soon enough, right Keith?
Old Feb 2, 2010 | 07:48 PM
spdmpo's Avatar
spdmpo
Yes sir, hook up to someone else's trailer with crappy wiring a few times and you figure it out. It always seems to be those Carolina boys with the redneck wiring. j/k Do you guys even have to get trailers inspected there? I'd swear there are more trailers running around without lights and brakes, than there are with.
Old Feb 2, 2010 | 07:52 PM
zx250's Avatar
zx250
Yep, you are so right there, My pop is the only man I know that swears everyone elses truck is wired wrong but his and that's because he did it himself. Blown plenty of fuses on my truck trying to pull his little trailers. Finally rewired the trailer and his truck and now no more problems. You know, brakes worked with left turn, left turn with headlights and so on, until you did more that one at a time the POP goes the fuses.
canister's Avatar
canister
Same thing happened on a Honda I had. Turn signals and brakes lights worked but everything else electrical went out. Turned out that a wire behind the radio grounded out on a metal bracket. If you have an aftermarket radio I'd check there also and make sure there aren't any exposed wires.
Old Feb 2, 2010 | 08:00 PM
zx250's Avatar
zx250
I think he's found his problem with the fried trailer connector.
