So today i noticed that my dash lights and tail lights werent working. So i went fuse searching and found that #8 under the hood was blown. Replaced it turned on headlight switch everything came on for about a second and then the fuse blew again. Did it one more time with a 20amp and same thing. So now i have a short SOMEWHERE.
Question where in the world do I start looking? And dose any one have any suggestions of common areas. I know there is a common issue with our windshields leaking and allowing water to get to the under dash fuse box, but regardless there is no water anywhere in my truck.
The fuse blows when you turn what on? Turn off the dash lights before you turn the head lights on then you will kknow if it's in the dash lights or not.
