Weird electrical issue
Old Feb 2, 2010 | 03:23 PM
VR6Nutt's Avatar
VR6Nutt
Hey all - I've had a really strange electrical issue with my X since purchasing it. It seemed more apparent during the summer months. Randomly, when starting the engine, the radio, power windows, and map lights wouldn't work. I'd wait a while while driving and magically, they'd start working again. Well the same thing happened again last week....its not summer and hot (yet). Happened while driving, the kid opened the glovebox looking for something. Same issue: no lights in the glove box, either. Approx 5 mins afterwords, everything started functioning normally. I've checked fuses and panel wiring; making sure it wasn't getting wet and I am lost! Has anyone had a problem similar to this? Suggestions???
Old Feb 2, 2010 | 04:48 PM
Black 03 Exc.'s Avatar
Black 03 Exc.
I had the same exact thing happen to my Expedition last year, except it didn't matter what season or temp. it was and then it began having trouble starting. Changed the fuel filter and checked fuses but nothin. We would also be able to hear almost like a sizzle but not the same behind the radio in the dash when it happened most of the time. We finally ended up trading it in. During a hard rain we would get some drips from the drivers grab assist handle but I never tore it apart to find the problem, just got rid of it. Could of been a big contributing factor I guess. Oh yeah forgot to mention the tranny started acting up in it as well.
Old Feb 2, 2010 | 09:33 PM
wallz's Avatar
wallz
I haven't had the problem, but from reading on here there seem to be a few possibilities.
1.The grounds. Check them out, including the battery terminals.
2.The other possibility could be water intrusion into the fuse panel. Easy way to look would be to pull out the fuse panel and look behind it for corrosion. If you find some, you need to take care of the water leak in the windshield before you can get rid of the corrosion.
Old Feb 3, 2010 | 06:41 AM
DSMMH's Avatar
DSMMH
It sounds like dirty relay contacts. Check your owners manual for problem related relays. I would start by swapping the "delay timer" relay with another relay. If that solves the problem, take the relay cover off, remove the moving arm (very easy to do) clean the contacts with crocus cloth or Scotch Brite and reassemble. Most of the time a black residue builds up on the contacts. If you have a lot of miles on your X and electrical gremlins start showing up, relays are a good place to start. When I had my relay issue I ended up taking them all apart and cleaning them. It is a lot cheaper then buying new relays from Ford. Another supplier option is Radio Shack. Basically, any standard SPDT 30 AMP relay will work. If you are not familar with relays, here is a site that will help.
Relay - Wikipedia, the free encyclopedia
DSMMH
Old Feb 3, 2010 | 09:40 AM
VR6Nutt's Avatar
VR6Nutt
DSMMH
Ya I thought about relays as well. Those are in the same location as the fuse panel right? Which one is this "delay timer" you refer to?
Old Feb 3, 2010 | 12:08 PM
DSMMH's Avatar
DSMMH
Look in your owners manual. It will tell you all you need to know.
DSMMH
Old Feb 3, 2010 | 12:25 PM
VR6Nutt's Avatar
VR6Nutt
You mean I gotta !!
Well it isn't in front of me as I am at work
Just doing research beforehand...
Old Feb 3, 2010 | 01:19 PM
luxury's Avatar
luxury
I have the same problem. Check out this thread:
https://www.ford-trucks.com/forums/7...ml#post7790815
Old Feb 3, 2010 | 02:20 PM
VR6Nutt's Avatar
VR6Nutt
Thanks Luxury! Did your problem come back? Or is that switch still in place?
Old Feb 3, 2010 | 03:35 PM
luxury's Avatar
luxury
I still have the switch in place, but I haven't had to use it for a few months, since it's been plenty cold here. It's definitely heat related.
nikki84hatingford
Mar 5, 2017 12:56 PM
JoeKan
Jun 22, 2016 06:10 PM
Icefan71
Feb 8, 2013 01:58 PM
yachtonwheels
Offroad & 4x4
Dec 23, 2010 10:59 AM
'08FX4
Dec 30, 2009 01:38 PM
