Engine Size?
Old Feb 2, 2010 | 12:22 PM
dadsranger's Avatar
dadsranger
Engine Size?
Got a motor from a 1972 F-100. I know the motor is not original, but not sure what it is. I looked for the casting numbers but they are not there. I think it may be an after market block. I would like to use the parts from this motor to finish a 351w that I have, but not sure what this one is. Couldn't find the casting numbers on the heads, but the number on the intake is D10E-9425-AA. I checked and found out that the intake is from a 71 Fairlane or Torino. Any ideas on the size of the engine?
Old Feb 2, 2010 | 01:00 PM
85e150's Avatar
85e150
Are the valve covers trapzoid in shape? The ends angled like so: /----\
Top radiator hose goes horizontally into the intake?
You can find pictures on the internet.
The 351W looks the same, but is a taller block with a wider intake. Heads interchange between the 302 and 351W, but little else.
Old Feb 2, 2010 | 02:42 PM
dadsranger's Avatar
dadsranger
I know the distributor interchanges if that helps.
Old Feb 2, 2010 | 03:00 PM
starmilt's Avatar
starmilt
If it looks like your 351 in size measure the width of the intake, if it is the same it is a 351w if it is narrower it is 302 or 289. I have never heard of an aftermarket block for these.
bjones10919
Feb 10, 2015 11:45 AM
StockMan
Jan 8, 2013 02:19 PM
nastar44
1966 - 1977 Early Broncos
Jun 3, 2011 08:51 AM
Truckboy
13
Jun 28, 2007 06:06 PM
glanzer_51
Jun 11, 2007 12:59 AM
