tidewater engines
thank you mr. helper
I think he is asking for a price on Complete drop in.
MANY TO CHOOSE FROM BUT HERE IS ONE CHOICE
XC3Z6007CARM LIST $9482.56 exchange
way way complete,
The Remanufactured 7.3L Power Stroke ® Diesel is a proven performer
Remanufactured Power Stroke ® Diesel engines such as the 7.3L are the only engines authorized by Ford Motor Company. These engines have been rigorously tested, with Ford Motor Company approving each remanufacturing process to ensure compliance to original equipment standards.
- Every remanufactured diesel or component is brought back to original equipment specifications, which helps assure a reliable and trouble-free product
- Every 6006/6007 engine is live run and dynamometer run and evaluated at normal operating temperatures and at a wide level of RPMs
- All 6009 and 6012 trim levels are 100% evaluated on computer-controlled testers which simulate vehicle conditions to help assure trouble free operation
- Test results for all engines are printed and included with each remanufactured engine shipment.
- Cylinder bores are diamond plateau honed to original OEM specifications
- Cylinder heads are new or remanufactured: no welding to combustion chambers
- New or remanufactured crankcase: inspected for cavitation (IDI only)
- Crankshaft remanufacturing includes 3-step heat treat process
- Turbocharger remanufactured to original OEM specifications
- Injectors are remanufactured to OEM specifications
- High pressure oil pump remanufactured to original OEM specifications
- Camshaft remanufactured to original OEM specifications or replaced with new crankshaft
- Oil pump remanufactured to original OEM specifications
- Water pump new or remanufactured to original OEM specifications
- New lube oil cooler - not cleaned or re-cored
- 100% valve guide inserts: new valves (DIT only)
- New premium glow plugs
- New cover gaskets
- New thermostat
- New coolant heater - standard equipment
- New breather
6007 Complete and 6006 Stripped Ford/Motorcraft ® (6.9L IDI, 7.3L IDI, 7.3L IDIT, 7.3L DIT, 6.0L DIT) Diesel Engine Assemblies:
- Parts (except those noted below) and labor are covered against defects for 24 months/unlimited miles
- Fuel filter assembly and lines, fuel transfer pump, harnesses, sensors, switches, relays, glow plugs, fuel injectors, injection pump and lines are covered against defects for 12 months/unlimited miles
