Bed not lined up?
Old Feb 1, 2010 | 03:30 PM
mike1589's Avatar
mike1589
Bed not lined up?
the bed on my 78 f250 isnt lined up, so I loosened up the 8 bolts today and tried to move it. I can pick it up so i know everything loose, but it wont slide. Im assuming theres room for the bolts to move in the holes if its not lined up in the first place. Am i wrong? any ideas why the bed isnt moving?
Old Feb 1, 2010 | 04:11 PM
fordtech08's Avatar
fordtech08
I'm not familiar with taking the bed of these trucks off, but could you have some build up on the frame not allowing it to slide? also what's not lined up?
Old Feb 1, 2010 | 04:17 PM
mike1589's Avatar
mike1589
well there shouldnt be build up cuz once loose i can pick the bed up off the frame at alll the mounts. And its further over to the driver side than the passenger side (quite noticably)
Old Feb 1, 2010 | 04:25 PM
fordtech08's Avatar
fordtech08
is your fuel tank hose stopping you?
Old Feb 1, 2010 | 04:28 PM
mike1589's Avatar
mike1589
good thinkin, but no its has no play either way at all
Old Feb 1, 2010 | 04:33 PM
gnwalker's Avatar
gnwalker
try harder, theyre heavy beds sometimes it takes a lot to make them move a little bit
Old Feb 1, 2010 | 04:44 PM
mike1589's Avatar
mike1589
so there definitely should be play right? the bed should move with a little more force?
Old Feb 1, 2010 | 05:02 PM
gnwalker's Avatar
gnwalker
When I've moved mine all I gota do is remove the 8 bolts and tug away. There should definately be room to move. I've gota give it a good yank to move it a couple inches
Old Feb 1, 2010 | 05:13 PM
mike1589's Avatar
mike1589
ok ill give it a try again tomorrow now that I know it should actually move, thanks for the info
Old Feb 4, 2010 | 12:11 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Actually, the bed doesn't move on the frame. The eight holes in the frame are round, not slotted, so there isn't any adjustment to speak of.
Old Feb 4, 2010 | 12:14 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Here is a picture of my frame, while not too detailed, you can see that the holes are round.
Old Feb 4, 2010 | 09:46 AM
mike1589's Avatar
mike1589
yaa i see what you mean...thats weird, i guess maybe ill have to make new holes.
Old Feb 4, 2010 | 09:57 AM
fordtech08's Avatar
fordtech08
do you have a pic so we can see how far off it is maybe there is another problem?
Old Feb 4, 2010 | 10:47 AM
4x4 Bart's Avatar
4x4 Bart
There should be a small stack of shims on one or both of the front corners. The shims have a dimpled center that fits tightly on the bolt and centers up on the hole when you lower the bed to the frame. If these washer are still present, they will cause the bolt to center in the hole. You need to remove these and use regular washers. This should give you a little adjustment. If you need more than this you need to do some measuring and find out what is causing the misalignment.
Old Feb 4, 2010 | 02:48 PM
mike1589's Avatar
mike1589
i actually figurd it out, when my friend who owned the truck before me built the truck, he made the floor of the bed out of wood, he must not have put the brackets on the bottom on right, ill have to drill some new holes
Trainhound
37
Sep 29, 2014 04:04 PM
davewave649
Dec 21, 2012 07:25 PM
puroford
May 14, 2012 12:14 PM
icrman
All Things Towing
Mar 10, 2008 06:43 PM
pancake
Apr 26, 2004 06:02 AM
