Installing B&W hitch
Old Mar 6, 2008 | 12:52 PM
icrman's Avatar
icrman
Its on a 96 F250, the 1 inch holes did not want to line up, with out grinding releifs so the side plates would clear the shock bracket rivets, and had to try to move bed closer to the cab, the outfit I got it from says they gota line up, and so did the factory guy. Anyone else have problems with this? The instructions said the hole in the bed at 49 inches from rear, its right on the money.
Also I want to put ride rites on it, and that 1 inch bolt would not let the bracket fit in position.
Thanks
Old Mar 6, 2008 | 07:24 PM
cangim's Avatar
cangim
Maybe they sent you the wrong hitch brackets? Mine lined up perfect when I did mine. I also have Ride Rites on mine as well.
Old Mar 6, 2008 | 09:56 PM
icrman's Avatar
icrman
Do you have pictures? It is the correct deal, it wasn't sent to me I got it from a local dealer in hitches. I even talked to the factory rep. Something could be tweaked on the truck as well. Maybe the 1 inch holes are off towards the front some, and yes maybe the side rails are off, but since I ground on them I don't think they would take em back.
Old Mar 6, 2008 | 11:07 PM
cangim's Avatar
cangim
There are a couple in the posting gallery, but all I have is those that are painted.
Old Mar 10, 2008 | 01:59 PM
jomac11's Avatar
jomac11
It depends on whether the truck is shortbed or longbed...
Old Mar 10, 2008 | 06:43 PM
icrman's Avatar
icrman
Well I got the 1 inch holes to line up. I got the bolts in and the ride rite brackets clear the bolt as long as it does not have a washer on it.
Its a long bed, I'm doing another post on it. I wish I knew how to put pictures on here.
99expyTN
Sep 20, 2013 04:00 PM
Psyclopse
Jan 22, 2012 12:11 AM
99f350sd
May 24, 2011 03:11 PM
webrx
Jun 13, 2009 07:21 AM
betrayz
Jan 4, 2008 06:39 PM
