Engine MPG
Old Aug 23, 1999 | 11:16 AM
iceman's Avatar
iceman
Engine MPG
I have a choice between which engine I can put in my truck I was wondering what would a 78' F150 with a automatic get for gas mileage if it had 360, 390, 351m, and 400m in it? Also what is the horse power and torque rating of these four engines?Also what is the most reliable engine of the four?
Old Aug 23, 1999 | 05:38 PM
390fe's Avatar
390fe
Engine MPG
I have a '70 F100 with a 390 C6, 3.50 gears, and a two barrel carb. My truck weighs 4100 lbs with a full tank of gas. It gets eight to 15 miles per gallon, depending on what I'm doing. Reliability? In the 80,000 miles I've owned it(for a total of 160,000 miles), I've replaced the timing gears and chain, camshaft(due to timing chain and nylon gears), two burnt exhaust valves, 56 spark plugs, three wire sets, 40 gallons of oil, and 32 oil filters. I think it's pretty reliable!
Old Aug 23, 1999 | 06:33 PM
Kikker's Avatar
Kikker
Engine MPG
390fe,
I'm sure glad to see ya keep good maintance records.
What would you think would be the tallest gear
I could run with my 65, 240-6 with 3 speed?
Old Aug 23, 1999 | 09:15 PM
390fe's Avatar
390fe
Engine MPG
It has 275 horse and about 400 ft/lbs torque from the factory.
Old Aug 24, 1999 | 05:07 AM
jowilker's Avatar
jowilker
Engine MPG
Red-Tail
Jul 2, 2010 12:59 PM
Aquaman78F100
1983 - 2012 Ranger & B-Series
Jan 21, 2008 02:52 PM
THE KING
Oct 28, 2007 09:48 PM
amartin98
Mar 27, 2006 06:15 PM
mike390
Aug 10, 2004 02:08 PM
