390 4-speed
Old Aug 8, 2004 | 12:55 AM
mike390's Avatar
mike390
Question 390 4-speed
okay i have a 78 f100 with a 302 and a 3-spd collum shift also i have a 74 f250 with a 390 backed by a c-6 i plan on putting the 390 in the 78 model but i want to change the c-6 to a 4-speed what is a good four speed four the 390 the truck i'm putting it in has a 9inch rear end with 3.00 gears
Old Aug 8, 2004 | 08:25 AM
jowilker's Avatar
jowilker
Mike, Any reason for going to the 4 spd? The C6 is an extreemly good tranny, and will do about any job thrown at it.
John
Old Aug 9, 2004 | 03:05 PM
85e150's Avatar
85e150
Lots of good 4 speeds--do you want to pull like a truck, or run like a car?
T18 or T 19 for truckiness
Toploader for that dragstrip sound.....
Old Aug 10, 2004 | 02:01 AM
mike390's Avatar
mike390
what bell housing will i need i want it to run like a car
Old Aug 10, 2004 | 08:42 AM
docholiday72tx's Avatar
docholiday72tx
I have a 73 F100 that had a 390/4 speed / 3:00 gears. My 4 speed was a new process grand ma. It was ok. I think the Borg warner T19 Acase would have worked better. That top loader is an option, how ever you will have a hard time finding a shifter and the top loader is a very expensive transmision and hard to find. That C6 would probably be the best choice unless you just have to have a standard. If the standard is mandatory, go for the T19. It's a big tranny like a grand ma, but the 1st gear is synchronized and higher than grand ma. If you get the B/W make sure to get the "A" case. The others have regular grand ma gears.
Old Aug 10, 2004 | 02:08 PM
85e150's Avatar
85e150
Check this out for toploaders:
http://www.4speedtoploaders.com/
Note he does a couple of shifter locations for different cars and trucks.
Like said, it ain't cheap.
You probably want a car bellhousing--I hear truck bellhousings are deeper.
Check the threads around here for other links to tranny sites.
BelJask
May 3, 2016 06:19 PM
036.0stroke
Feb 16, 2016 11:21 PM
pcpotter1023
Jan 27, 2016 12:26 PM
mlwarriner
Engine Swaps
Oct 8, 2015 08:25 PM
Hondaman416
Sep 7, 2015 01:39 PM
