The DP ?
Old Jan 31, 2010 | 08:44 PM
deerslayer165's Avatar
deerslayer165
The DP ?
Well I got my DP F6 last week and installed it the day I got it. I followed all of the directions exactly as written and got it in fairly easily. I was about 99% sure I cleaned the ports well enough, as the directions state, but when I got everything put in and back together, I put the key in turned it half way and everything was normal, dash lights were on, DP switcher light on, but when i turn the key everything shuts off and I hear a continual clicking noise under the hood. I had to go on a trip this weekend and got back tonight and figured id give it another shot at cleaning the ports. I got everything out, cleaned it again, once again being 99% sure itd work this time, and the same thing happened again. Im hoping I didnt fry anything. I never had any static sparks or anything else that would concern me happen. Does anyone know what else could be wrong? Im gonna call DP tomorrow and try to get things worked out. Thanks.
Old Jan 31, 2010 | 08:49 PM
F350-6's Avatar
F350-6
Clicking noises usually means weak batteries or a bad / corroded connection. I'd suggest cleaning your battery cables (both ends) and putting the batteries on a charger.
Old Jan 31, 2010 | 09:24 PM
duck fan's Avatar
duck fan
Because racetruck
also, ensure your DP is not set in the "no start" tune.
Old Jan 31, 2010 | 09:42 PM
clux's Avatar
clux
X2 on charge the batteries.
Old Jan 31, 2010 | 10:25 PM
PwerStroke99's Avatar
PwerStroke99
make sure when installing and takign the chip out that u have those keys as far away from the ignition as possible
Old Jan 31, 2010 | 10:37 PM
SpringerPop's Avatar
SpringerPop
My vote, too, is battery charge or corroded battery connections.
Pop
Old Jan 31, 2010 | 11:02 PM
schlepprock250's Avatar
schlepprock250
I'd say this is a pretty BAD choice for a new thread title.Just my.02 worth of course.
Old Jan 31, 2010 | 11:05 PM
Vinford's Avatar
Vinford
My thoughs also.............................
Wasnt what I was excpecting when I saw the title.
Old Feb 1, 2010 | 07:27 AM
zx250's Avatar
zx250
Of the next Riffraff East
I've had my DP-Tuner in and out several times for different reasons and never had that happen. I have also had weak batteries that did do exactly that. Chances are, you had you hood up and door open long enough to drain your already weak batteries to the point they wouldn't start it. Simple enough to check with a DMV. A better title could have been used.
Old Feb 1, 2010 | 07:32 AM
Talyn's Avatar
Talyn
You should always unplug the battery(s) when installing a chip or taking it out.
And yea, the thread tittle is funny! haha
What he didn't say is if it starts without the chip.
Old Feb 1, 2010 | 07:39 AM
jh225's Avatar
jh225
Yeah, let's play with electrical components without disconnecting the batteries and then blame it on the tuner. This crap is getting real old, real fast.
Old Feb 1, 2010 | 07:44 AM
Talyn's Avatar
Talyn
He could have had it on the "kill my PCM" setting while installing it.
HAHAHAHA.
Old Feb 1, 2010 | 08:06 AM
clux's Avatar
clux
The forum is getting a little testy about DPTuner threads, isn't it?
Old Feb 1, 2010 | 08:27 AM
zx250's Avatar
zx250
Testy, maybe. It just seems so easy for folks to jump on the nearest band wagon to blame their problems on rather than take a moment and think for themselves. Titles like that does no one any good and I'm sure when he gets his batteries up to par, he will start another thread praising his new found power, that is if pride will allow him. :-)
Talyn's Avatar
Talyn
Clux, thats cause Super Duty guys are way to up tight about DP tuner.
I know its your forum sponsor, but man.
I swear, all SD guys ever say is how much other tuners suck and how great DP tuners are.
So any DP tuner threads like this are amusing to me.
I believe that DP makes a good tuner. Would I put one in my truck? Probably not, it does not fit the profile for what I want to do.
So, all in all, I think guys need to lighten up a bit on it.
Though, the thread title does suck. haha.
