lift kits
Old Jan 31, 2010 | 07:34 PM
1997f350stroker's Avatar
1997f350stroker
lift kits
wanna get a lift kit. got about 750 dollars for the lift wondering what i should get and waht size tires. anyone have pics of what it will lok ,like?
Old Jan 31, 2010 | 09:02 PM
c00nhunterjoe's Avatar
c00nhunterjoe
750 isnt going to get you a whole lot and definatly wont get you a lift and tires. what exactly are you looking to do with the truck? is the kit for looks or do you want it to perform offroad? do you plan to tow heavy loads with it or just the occasional car trailer? need more info about what your plans are to give you advice on what kit to get.
but anyways, here is my truck with 6 inches of spring lift, no lift blocks in the rear. at these pics it is turning 36's
Old Feb 1, 2010 | 12:04 PM
1997f350stroker
im going wth 750 for a lift then wheels and tires after planning to do 36's i usually jsut tow the occasional car trailer. it will be jsut for looks hgave a different off road truck
Old Feb 2, 2010 | 06:55 PM
rolltide3006's Avatar
rolltide3006
coonhunter- can you do spring lift with blocks? I was thinking about getting the 6" skyjacker. Could I also put some blocks under those?
Old Feb 2, 2010 | 09:19 PM
stewart460's Avatar
stewart460
i want a total of 6" and put 37s whats an option i was looking at the 6" skyjacker too but does that give me 6" of what i got now like keeps the blocks in
Old Feb 8, 2010 | 02:26 PM
sand1's Avatar
sand1
oru has a shackle reversal kit gives u 2.5 of lift then u want a spring to go higher but to do a lift right on these trucks will cost u 2000 and up
Old Feb 8, 2010 | 05:57 PM
PIKE's Avatar
PIKE
Get one of these lift kits,its the one you will end up with after all.The Dana 60 lift kit
Old Feb 8, 2010 | 10:29 PM
c00nhunterjoe
with the spring kit you keep the stock blocks. the 250's stock block is a 2 inch, you could swap in a 350 block (4 inch) to get a little extra height. much more then that and you will run into serious driveshaft angle issues. you will have to change to a double cardon front shaft to prevent drive line binding while using 4wd on a 6 inch kit.
stewart, i have a 6 inch skykjacker kit and i have 37's on my truck now
Old Feb 9, 2010 | 11:32 PM
PIKE's Avatar
PIKE
Now this poster knows what he is talking about,add a Dana 60 and you are golden no cheesey stamped parts.
Old Feb 10, 2010 | 10:21 AM
c00nhunterjoe
cheesy stamped parts? what are you talking about?
Old Feb 10, 2010 | 03:03 PM
fishmanndotcom's Avatar
fishmanndotcom
lol i think he is attempting to make a joke saying that a D60 is a lift kit
-cutts-
Old Feb 10, 2010 | 03:07 PM
PIKE's Avatar
PIKE
Shackle reverse+Dana 60 installed=Cheesey stamped parts removal
Old Feb 11, 2010 | 02:07 AM
firman's Avatar
firman
with the 6inch lift did u have to lengthen drive shafts.
Old Feb 11, 2010 | 09:34 AM
PIKE's Avatar
PIKE
Yes I did,opinions will very on this but I did lenghten the front and lower the rear,at the carrier bearing.
Old Feb 11, 2010 | 09:47 AM
c00nhunterjoe
what parts on my truck are you saying are cheesy stamped parts? i think you are nothing more than member who looks to start trouble.
the reverse shackle and superduty springs are fine for a "road queen" you will not get more performance out of the reverse shackle lift offroad.
besides that, he says he doesnt want to go much more then 750 for the lift. just the dana 60 alone is averaging 1200 for just an axle, then you typicly have to go through it and replace ball joints and steering components, add the track bar brackets and buy a longer bar, and you are easily at 1500 for just the axle. then buy the sd springs and shocks and you are way overbudget. AND after that, you have a solid axle instead of an independent front end. the independent axle will perform much better offroad any day of the week and it rides better onroad as well
