Carb problem need help
Old Jan 31, 2010 | 07:10 PM
Welder10's Avatar
Welder10
I have a 79 F-250 with a 460, it acts like it's starvin for fuel. Had this happen b-4, I pulled the filter out of the carb and cleaned it and that seemed to solve the prob. It has a Holley D9TE-9510-AEA list 8343 then below that it says 1998. I put a pressure guage on the fuel pump and it's pushing 4 psi, is that enough? can't find any holes in the FP diaphragm, do you think a carb rebuild would solve the prob?...
Old Jan 31, 2010 | 07:33 PM
johnboy427's Avatar
johnboy427
Check the condition of the fuel lines between the pump and the tank they can get old and rotten and the pump will suck air instead of fuel. My 79 did this, the line coming out of the tank was really bad and it would only hold about 3-4psi of pressue and barely moved the gauge a idle.
-Johnboy
Old Jan 31, 2010 | 07:38 PM
Welder10's Avatar
Welder10
So 4 psi is not enough? What would you say normal psi would or should be?
Old Jan 31, 2010 | 07:40 PM
mark a.'s Avatar
mark a.
4# is low it should have around 7#
Old Jan 31, 2010 | 07:41 PM
johnboy427's Avatar
johnboy427
4psi at idle should be fine but I have about 6-7 if I rev up the engine.
-Johnboy
Old Jan 31, 2010 | 07:42 PM
Welder10's Avatar
Welder10
That makes sense, b-cuz I haven't been able to run off my back tank for awhile now...
Old Jan 31, 2010 | 08:25 PM
zwinstead's Avatar
zwinstead
Sounds like a fuel problem behind the pump. There are several rubber hoses and they can get cracked or collapse all together. Check those and see what you find.
joedirt1971
Aug 14, 2015 07:10 PM
Bobz1x
Jun 26, 2014 12:34 AM
F-250 restorer
Dec 8, 2012 05:27 PM
kona56
Feb 2, 2010 09:44 AM
jimbeam&coke
Nov 29, 2009 09:36 PM
