10-12 is what you will set it too with the advance unhooked at idle. The 36-38 is the total when you are driving down the road and have the advanced hooked up.
-Johnboy
-Johnboy
Wrong.
Initial is correct, this is set at idle, VACUUM advance disconnected and plugged.
TOTAL advance is the mechanical advance built into the distributor. Initial + Mechanical = TOTAL
Vacuum advance ADDS to mechanical. Which is why initial can be 10, total can be 38 and vacuum can be over 50 if you aren't carefull.
I will admit my explination of total advance wasn't great but I said correctly explained how to set the initial and I really doubt he is going to check the total.
-Johnboy
I usually don't worry about initial timing unless it won't crank easily (too advanced). I start at 35 at 3000 rpm and then check for pinging. If there is pinging back it off a bit or if not advance it some more and then curve the distributor so most of the timing comes in before 2500 and don't run a vacuum advance, has worked great for many many years.
