Guages died
Old Jan 31, 2010 | 04:21 PM
Ted928's Avatar
Ted928
Guages died
While driving, all the guages died for 2 seconds. Then they came back up and cycled and read fine except the airbag light stayed on. The illumination did not stop and the engine did not die. The airbag light went away later, once I restarted the engine.
This is the second time it has occurred.
Has anyone else had this problem?
Thanks
Old Feb 1, 2010 | 03:40 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
How old is you battery is it original if so may be going bad causing strange stuff to happen to electrical stuff.
battery seems to be the problem moat of the time they just go without warning.
something to check.
Old Feb 7, 2010 | 09:36 PM
Ted928's Avatar
Ted928
something to check.
It seems to crank fine. I'll have it checked. On two occasions the red charging light lit for a brief moment while driving but the the gauges did not die. Perhaps it is just a bad connection to the cluster.
I am going to change out the alternator. The truck has always made a strange noise when cold (10F) and many have concluded that it is the alt bearing. It has gotten worse as it makes the noise at higher temp (30F).
Old Feb 17, 2010 | 07:08 PM
Ted928's Avatar
Ted928
The battery tested out fine.
I replaced the alternator. Only time will tell if the guage dieing problem is gone but the cold weather "whistle" is finally gone. If it were not for this forum, I never would have guessed that it was the alt causing that annoying cold weather noise.
Old Feb 19, 2010 | 12:53 PM
jstnromero's Avatar
jstnromero
it is amazing what the cold weather can reveal about these trucks....hope all works out now
oldshakey
Jul 13, 2011 04:57 PM
timsexcursion
Jan 17, 2011 04:04 PM
brc777
1997 - 2003 F150
Oct 15, 2009 09:46 PM
fordtrucksforever
1978 - 1996 Big Bronco
30
Mar 14, 2006 07:26 PM
bdee
1983 - 2012 Ranger & B-Series
Nov 24, 2004 07:21 PM
