1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Gages Quit and Truck Won't Run
Old 01-17-2011, 11:54 AM
timsexcursion's Avatar
timsexcursion
timsexcursion is offline
2000 Excursion with 7.3L...
Today the truck had been running for a couple hours. Got out to do something and when I got back in I put the trans in reverse and the gages died except the tach. Stepped on the pedal and no response (engine still idling). Then the tach died after 10 seconds. Shut the truck off. Turned key on and all I have is a battery light and airbag light nothing else. Engine will crank (with no tach indication) and run for 1 second and quit. Any thoughts?
Would CPS cause the electrical problem?
Thanks
Old 01-17-2011, 12:17 PM
timsexcursion
Got the following codes
P1139 Water in fuel circuit error
P0381 Glow plug indicator circuit error
P1260 Theft detected, vehicle immobilized
P1670 EF feedback signal not detected
These are listed in order of detection. I had a water in fuel problem a few months back that was fixed so I don't think it is applicable...
I also have Superchips towsafe installed with about 80,000 miles driven since...
Old 01-17-2011, 12:22 PM
tdpower's Avatar
tdpower
tdpower is offline
Sounds like the wire going to the shifter could be rubbing. Should be fuse #19 on your truck. Check this pdf.
Old 01-17-2011, 12:45 PM
timsexcursion
Hey I think that might be it...my fuse #19 is blown which controls
Instrument cluster, GEM module, Overdrive Cancel Switch, PATS transceiver, Idle Validation Switch
Seems to match the codes too.
Thanks for the article link!
Tim
Old 01-17-2011, 04:04 PM
carltonwebb's Avatar
carltonwebb
carltonwebb is offline
Dang....less than hour first post to fix......Now thats service.
JayzDaddy
01-09-2013 08:51 AM
pkm
34
12-09-2011 02:45 AM
fhafer
12-26-2010 04:02 PM
fairfield86f150
33
04-16-2008 09:38 PM
Chopper-Boyz
1983 - 2012 Ranger & B-Series
04-25-2006 07:01 AM
Quick Reply: Gages Quit and Truck Won't Run
