Airbag Light
Old Jul 13, 2011 | 12:21 PM
oldshakey's Avatar
oldshakey
Airbag Light
Am getting airbag light 1 flash followed by 2flashes then 5 seconds later light repeats.Any suggestions
Old Jul 13, 2011 | 12:40 PM
lincolncobra4.6's Avatar
lincolncobra4.6
be sure the charging system is working properly. i have come across a few that needed an exciter in the altenator and would not charge at idle when started, unless engine is reved up soon as started, light would go out. check this first.
Old Jul 13, 2011 | 01:07 PM
SideWinder4.9l's Avatar
SideWinder4.9l
Since you didn't add what year the truck is, it makes it a bit harder to help you....
Anywho...On my 94, the airbag light lit up simply because there were a connection, etc loose, broken, whatever.....The airbag light should be its own little circuit; Dedicated solely for the Airbag....
Old Jul 13, 2011 | 01:18 PM
oldshakey's Avatar
oldshakey
airbag problem
Thanks lincolncobra 4.6 I checked and the light stays on all time. Alternator voltage checks good
Old Jul 13, 2011 | 01:25 PM
lincolncobra4.6
if i recall correctly there is a small blue box on drivers side under dash, this sends the correct voltage to the ars modual. replace it. some say it has a small battery inside, but, i've never seen one.
Old Jul 13, 2011 | 02:14 PM
oldshakey's Avatar
oldshakey
Thanks again for your timely response. I will obtain the blue box you describe and give it a whirl
Old Jul 13, 2011 | 02:32 PM
RustyGreen's Avatar
RustyGreen
https://www.ford-trucks.com/forums/1...-air-bags.html
I found this thread that lists all codes for air bags light flashing, Hope it helps
Old Jul 13, 2011 | 04:57 PM
oldshakey's Avatar
oldshakey
Airbag Light
Thanks Rusty. It helps to know what the codes are
elee3
Jul 31, 2009 11:06 AM
fordtrucksforever
1978 - 1996 Big Bronco
30
Mar 14, 2006 07:26 PM
Fullcontact
1983 - 2012 Ranger & B-Series
Mar 8, 2006 06:58 PM
chaser1602
1997 - 2003 F150
Aug 31, 2005 12:37 PM
marragtop
Oct 22, 2002 09:40 PM
