Sponsored by: Real Truck
Can 2003 adjustable pedals be changed?
Old Jan 30, 2010 | 02:20 PM
2003larry's Avatar
2003larry
2003 f-250 7.3 deisel with adjustable pedal. Ford shop says it is bad with a dead spot so it jerks if you don't put your foot in it or have load. Over $800 for part not including labor. Can it be replaced with fixed pedal or not?
Old Jan 30, 2010 | 05:40 PM
TennesseeMustangPerf's Avatar
Dunno if they will interchange, but $800 is a little insane for a stupid pedal that is not used all that often.
Hate to be smart here, but I say set it and forget it.
Old Jan 30, 2010 | 07:27 PM
2003larry's Avatar
2003larry
engine jerks if it's not under load no matter where pedal is set. dead spot so cuts out. fixed pedal is alot cheaper.
Old Jan 30, 2010 | 08:36 PM
mrford60's Avatar
mrford60
you should be able to replace with a fixed pedal, the mounting is the same to the firewall.
Old Jan 30, 2010 | 09:06 PM
Ah, sorry, I thought the pedal was jerking when you went to adjust it unless the pedal loaded. That is indeed a problem. Yes, you should be able to replace it with the manual, but I am not 100% on that.
myexpo02
29
Nov 1, 2017 05:27 AM
LightningRyan
2009 - 2014 F150
23
Nov 18, 2015 09:53 AM
Parts Guy Wyatt
2004 - 2008 F150
Feb 10, 2010 01:18 PM
dinikin
1997 - 2003 F150
Dec 15, 2009 06:23 PM
cacarroll
1983 - 2012 Ranger & B-Series
May 6, 2007 10:21 PM
