2005 6.0 overboost ??
Old Jan 30, 2010 | 11:44 AM
9228.bobcat's Avatar
9228.bobcat
O.k, I an 05 CC FX4 with 51k on it. It is pretty well stock other than straight pipe, cat delete, coolant filter, ccv reroute. Anyway, when I wot it the boost goes up to around 30 maybe even 31 psi. What I have been reading is that is a little high for a stock motor. If it is, what can I do to get it down about 2 or 3 lbs. I figured I might need a tuner but if anyone had any ideas I would be interested. The gauge I am going by is the stock gauge. My egt's are 7-900, fuel pressure is 51-58 lbs. Maybe the gauge is reading a couple of lbs more than it should?? I would the pcm goes by the gauge, correct? Anyway hope some one will chime in about it. Thanks, Eric
Old Jan 30, 2010 | 11:46 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
I wouldn't worry about it if you are looking at the stock gauge......Esp. if that's the ONLY thing that's odd. The EGT looks GREAT!
Old Jan 30, 2010 | 11:49 AM
9228.bobcat
right on. I guess the concern would be with this new flash, if it overboost it wants to throw the truck into limp mode I guess. The wrench light comes on then there is little boost unless you hammer it. Turn it off and turn it back on and it fixes it. It only does it when the boost gauge gets up to 30.
Old Jan 30, 2010 | 12:23 PM
bismic's Avatar
bismic
might be time for a turbo cleaning
51f1truck
34
Sep 11, 2019 01:52 PM
Scott in TX
May 26, 2016 08:44 AM
meborder
Jun 11, 2015 03:12 PM
99ExpyProblems
Oct 9, 2013 01:47 PM
koski19
20
Apr 27, 2013 10:16 AM
