Hello From Texas
Old Jan 30, 2010 | 12:58 AM
  #31
FordGuy91's Avatar
FordGuy91
I always have one with a few gallons in it for reserve, then the other one as my main. Every once in awhile I flip flop. Seems to keep the pumps in working order.
Old Jan 30, 2010 | 02:03 AM
  #32
court1100f's Avatar
court1100f
I know with my 87 with a 4.9L and C6 the towing package included a heavy duty radiator that was literally twice the size of my mothers 85 with same motor for additional cooling capacity
Old Jan 30, 2010 | 05:33 AM
  #33
TexasGuy001's Avatar
TexasGuy001
Welcome to the forums. I will say that if your truck is 2wd, just put some 31 10.50s on it and call it a day. I did the whole 2wd lift thing and took it all off. I won't ever do it again.
Trust me it adversely affects performance, handling, braking, etc. If your truck is your daily driver definitly don't lift the 2wd.
Old Jan 30, 2010 | 06:02 AM
  #34
SouthernBlues's Avatar
SouthernBlues
I have 35,s on my 95 2WD with a 3" Body Lift
Old Jan 30, 2010 | 09:59 AM
  #35
skyfox10's Avatar
skyfox10
Back when I had duel tanks. I filled both, started in the front, got down close to E, then switched to the rear. I've heard that running them to low can shorten fuel pump life. But the nice thing was, if I did get to the point were I ran out when i was on the rear tank. I could always go back to the front tank and use the last couple gallons in there to get to a fill station.
Old Jan 30, 2010 | 12:24 PM
  #36
skyfox10's Avatar
skyfox10
Well here are the springs from the trucks.
The tow package one actually has more leafs.
what is weird though is that they both have the same GAWR for the rear axle. But what's really weird, is that the tow package truck has a higher GAWR for the front axle. Anyone know why this would be?
Old Jan 30, 2010 | 01:48 PM
  #37
Hitokori's Avatar
Hitokori
hahaha maybe they printed the sticker wrong
Old Jan 30, 2010 | 05:05 PM
  #38
Josh93F150's Avatar
Josh93F150
Thanks everyone for there opinion and help, here are some more pics of the truck.
Here is what I need to fix on the truck.
I Love This Truck
Old Jan 30, 2010 | 07:01 PM
  #39
FordGuy91's Avatar
FordGuy91
Truck really is clean man. For $1,500 it looks like you got a steal. That dash piece should be easy to find at a junkyard or pick and pull if you got some nearby. If all else fails LMC has them I'm sure.
Old Jan 30, 2010 | 07:11 PM
  #40
Hitokori's Avatar
Hitokori
i agree with fordguy its nice and that piece should be really easy to find.... LMC must think they are made out of gold because they want $170 for theirs
Old Jan 30, 2010 | 07:50 PM
  #41
Josh93F150's Avatar
Josh93F150
Thanks for the complements, im goin to the pick n pull first thing tommorow morning to check it out. This truck runs perfect and smooth, its suprising how it just picks up and goes I have to look down at my speedo sometimes to make sure im not speeding.
Old Jan 31, 2010 | 09:13 AM
  #42
6CylBill's Avatar
6CylBill
A good 4'' suspension lift will allow you to rnu 33's, but 32's would fit better and look just as good. I like your ideas for the truck. For some reason I like seeing lifted 2wd trucks. I guess because it's different. My 2wd has a 3'' lift and 31'' tires. I have the same motor and tranny as you do, too. What gear ratio is in your truck? 3.08? If you plan on going to 33'' tires you'll want a 3.73 ger set to give you the power back and fuel mileage.
What type of exhaust work does it have? Do you like the sound?
Old Jan 31, 2010 | 09:16 AM
  #43
6CylBill's Avatar
6CylBill
That's weird, my truck has more springs too but it doesn't seem to matter. It sits nearly level and it doesn't take much weight in the bed to nose-me-up. Maybe my suspension is setup specifically for the lighter stepside box. Now I'm curious.
Old Jan 31, 2010 | 09:39 AM
  #44
skyfox10's Avatar
skyfox10
Now that's weird. I wonder what the difference is. One thing I really liked about that design with the mostly innactive upper leaf (overload spring) is that it doesn't add any extra height, but when you start getting the truck weighted down, it starts to kick in and prevent sagging.
can you get a pick of your springs bill?
Old Jan 31, 2010 | 10:38 AM
  #45
6CylBill's Avatar
6CylBill
I sure will Bud. You'll see I have about 5 leaves. They're more narrow than the normal leave spring though.
I can't get the pictures right now, but I can later today.
