Low Boost Question
Old Jan 29, 2010 | 07:58 PM
Redeyeracing's Avatar
Redeyeracing
Low Boost Question
So I have a 01 Ex with the 7.3. I just replaced the uppipes with Inter bellowed up pipes from Riffraf....I still believe that I am low on boost. My edge attitude is still only showing mid teens of boost? What else would cause low boost?
Old Jan 29, 2010 | 08:07 PM
riverrat41's Avatar
riverrat41
Have you checked your intake filter to see if it is clean?What shape are the boots on the spider?Show oil residue?
Old Jan 29, 2010 | 08:25 PM
roushcm's Avatar
roushcm
when i had my edge it would only show the same as yours. I replaced way too much before i took it in to get looked at. the shop told me everything was fine so i got a good set of autometer gauges and it showed my boost in the 20s but the edge still was reading low. So i got rid of the edge and got a Dp tuner and have never been happier.
Old Jan 29, 2010 | 08:28 PM
riverrat41's Avatar
riverrat41
That is a great point right there.I think you should varify the boost reading with an actual gauge then go from there....Reps to ya ROUSCHM
Old Jan 29, 2010 | 09:09 PM
Redeyeracing
Air filter is brand new and spider looks good. It is good to know that others have had reading problems with the Attitude monitor....I have thought about that. I got the Edge for free so I through it in. I plan on doing the DP, but need to do the intake and exhaust first....and since I just did the tranny and up pipes I'm in a holding pattern for a little bit. I will look at hooking up to a different guage and see what I come up with.
Thanks,
Nate
Old Jan 29, 2010 | 09:18 PM
camodown's Avatar
camodown
Check your intercooler piping on the drivers side. That one on my truck had a hole rubbed into it by the power steering pump supply connection...
Old Jan 29, 2010 | 09:44 PM
2000ca250's Avatar
2000ca250
also it may be a stupid question, but do you have any type of OBA? I believe the edge reads boost from the PCM and therefore the MAP, so if you have an OBA you could be reading teens but really getting higher
Old Jan 29, 2010 | 09:55 PM
Redeyeracing
OK...I'm going to show some ignorance.....what is an OBA?
Old Jan 29, 2010 | 10:01 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Riffraff Diesel: OCR - Overboost Code Regulator
Old Jan 29, 2010 | 10:22 PM
big poppa's Avatar
big poppa
Nice Clay...
GondolaRides
Jan 29, 2014 06:56 AM
LDP
13
Jun 16, 2012 10:00 AM
69Cobra
17
May 10, 2010 05:29 PM
bobrc
Aug 24, 2008 12:56 PM
mcbryant
May 15, 2003 05:49 PM
