Fuel System Issues....
Old Jan 30, 2010 | 05:26 PM
harwood39's Avatar
harwood39
not sure what blocked them, all i know is fuel wouldnt flow through 2 of them til i replaced those, than they all flowed fine. I am goin to go out and dump a thing of anti gel in the tanks, take a heat gun to the lines and see where i get from there...
Old Jan 30, 2010 | 05:41 PM
greywynd's Avatar
greywynd
Certainly sounds like a possible gelling issue to me. Drain the fuel filter, fill it with a good fuel conditioner (trying to recall which one Dave and others suggest) and see if it will fire. That will also put some through the IP and injector lines. If you can't get it in somewhere to warm up, you may want to disconnect the supply line at the lift pump, and back at the tank, and see if you can blow it through....sometimes it can be a real fight to get badly gelled fuel cleared out of long lines in cold weather.
Old Jan 30, 2010 | 05:49 PM
harwood39's Avatar
harwood39
they all like diesel kleen, as do i. that is what i am going to dump in the tanks too.
Old Jan 30, 2010 | 05:51 PM
starmilt's Avatar
starmilt
If it is gelled I like gas or diesel 911. unleaded works as good as anything but I wouldnt put it in the filter.
Old Jan 30, 2010 | 05:52 PM
harwood39's Avatar
harwood39
how much gas?? obviously not too much.
Old Jan 30, 2010 | 06:08 PM
starmilt's Avatar
starmilt
1 gallon per tank will be good but you will still need to warm the fuel in the ip and filter.
Old Jan 30, 2010 | 06:11 PM
charles09's Avatar
charles09
doesnt power service prevent this?
Old Jan 30, 2010 | 06:12 PM
harwood39's Avatar
harwood39
ya, i plan on warming both of those no matter what.
Old Jan 31, 2010 | 02:52 PM
Dave Sponaugle's Avatar
Dave Sponaugle
If you put the additive in before it gels, all antigells work wonders.
911 does a fine job in the tank, but if you have wax blocking a line or the filter, it has no way to get there.
A couple hours in a warm shop is the easiest way to get the lines cleared.
Out in the cold country, most road services bring a generator and one of those turbo heater out with a tarp cut about 4 feet tall with wood stays they can wrap around your truck to block off the wind under the truck.
Once the air is blocked off, the heater blowing hot air under the truck will thaw the paraffin blocking the fuel lines so fuel can flow through them.
As soon as you have flow, the 911 will take care of the rest of the wax.
CSIPSD
27
Oct 10, 2012 09:49 AM
DOK6969
New Member Introductions
Jul 10, 2008 02:28 AM
dbro8863
Apr 19, 2008 06:09 PM
alangill.1
Mar 14, 2008 06:53 PM
MT range
20
Nov 19, 2003 03:03 PM
