Where can I?
Old Jan 30, 2010 | 01:19 PM
charles09's Avatar
charles09
Where can I?
find a good quality fuel lines? mine right now are split and my brake lines are rusted. while im under the truck im going to replace both!
Thank you!
Old Jan 30, 2010 | 01:35 PM
starmilt's Avatar
starmilt
This I am not sure of. where are you located I just stripped a rust free 85 and kept every piece of the fuel system as well as the whole brake line system. lol
I have been intending to see if the air brake lines can't be used as fuel lines on our rigs.
Old Jan 30, 2010 | 01:44 PM
kenpobuck's Avatar
kenpobuck
I know that summit sales aluminum fuel line by the roll. You have to do your own connections. Also lmc truck sells complete fuel and brake line kits for our trucks but they are kinda pricey.
Old Jan 30, 2010 | 02:07 PM
starmilt's Avatar
starmilt
The nylon air brake lines are used for the fuel lines an all reefers and comes in 5/16 and 3/8 too. Im thinking our fittings will work with it and it is like 50 cents a foot or less.
Old Jan 30, 2010 | 02:13 PM
charles09's Avatar
charles09
Pikeville, Kentucky 41501
Old Jan 30, 2010 | 02:20 PM
starmilt's Avatar
starmilt
Yea I figgured you were back east if you had brake line trouble.
I have bought brake line in 25 foot rolls and with a bender and double flaring tool built new ones.
Old Jan 30, 2010 | 02:29 PM
charles09's Avatar
charles09
yea Im east. I think I can take my old ones off and match them up at napa they sell them by sizes. For the fuel lines I dont know about that.
Old Jan 30, 2010 | 02:38 PM
starmilt's Avatar
starmilt
Are you talking about the short lines to the wheels or the longer steel brake lines on the frame rails.
Old Jan 30, 2010 | 04:44 PM
greywynd's Avatar
greywynd
For brake lines once you have a double flaring tool it is fairly easy to make them from a roll of new line. All the steel lines on my dually were replaced about 3-4 years ago, and I think I did all the rubber hoses then too. For fuel line, I've been fortunate on the diesel so far, never had to touch them. My F150 gasser was a single tank, so when it started to leak it got switched to rubber, but with it the fuel pump was in the tank, so didn't have to worry about hoses collapsing or anything. Not sure if it would be a good idea in the diesels, but it would likely work.
Old Jan 30, 2010 | 06:10 PM
charles09's Avatar
charles09
yea i need to do something the driveway is already stained from it
Old Jan 30, 2010 | 07:03 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
i replaced to/from my tanks with standard rubber fuel hose.
routed and wire tired away from eveything.works good.
Old Jan 31, 2010 | 02:59 PM
Dave Sponaugle's Avatar
Dave Sponaugle
My guess is your fuel line problems are ther metal line from the fuel tank selector valve forward.
Those nylon lines from the selector valve back are rather tough and never rust.
