Egr cooler block off
Old Jan 28, 2010 | 11:55 PM
Dsl_Burner's Avatar
Dsl_Burner
Lightbulb Egr cooler block off
I have gone through 2 egr coolers in the past 2 years and now suspect another failure. I've thought about doing a complete delete but I still have warranty for another 7 months and don't plan on keeping the truck that long.
Is it possible to pull the egr cooler and weld both ends shut and reinstall or will this have some adverse effects?
Old Jan 29, 2010 | 12:49 AM
dave at BD Power's Avatar
dave at BD Power
Former Vendor
If you were keeping the truck we have a package that we offer for about 6000 that includes the EGR Delete, New Oil Cooler, Machined Heads, ARP Headstuds, Injector Flush and Reflash. It a bit pricey but its done right and become a nice truck like it was intended to be.
Old Jan 29, 2010 | 01:29 AM
Dsl_Burner's Avatar
Dsl_Burner
Thanks Dave but I will be moving on to a 6.4l or possibly the new 6.7l when it is available. I just want to rectify this egr cooler for the least amount of time and money. I work in the oilfield so my truck can't have alot of down time and its hard to shcedule dealer visits because I never know when and how long i'll be home. Nevermind I've had it in twice now for the tea kettle whistle and coolant residue on top of the resevoir with the dealer finding nothing wrong.
PS - Dave I love my BD short throw shifter
Old Jan 29, 2010 | 10:32 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
I've read on here about EGR by-passes. That is what I would like to read more about. Plenty of discussions about the delete kits. I have an 04 f350.
Anyone have a description or write up of an EGR by-pass?
Old Jan 29, 2010 | 01:10 PM
janton01's Avatar
janton01
I have a freeze plug welded into the input side of my and have had no problems. the system looks and works normally but no exhaust flow. 040 f250 03 late engine. Here in nj they are talking about inspections of the epa stuff on the diesel trucks so having the system intact is a good thing. So far no noticeable changes to the engine without the flow and no codes being set. Next project when it warms up will be emptying the cat. I also installed a coolant filter.
Old Jan 29, 2010 | 01:12 PM
desertt5's Avatar
desertt5
Did they replace your oil cooler also? A coolant filter sounds like a good fix to your issues.
Old Jan 29, 2010 | 02:10 PM
janton01's Avatar
janton01
Yes when removed the coolant passages were just about completely clogged with casting sand. $2500 later with a new oil cooler and new egr cooler (old one pressure tested good but not taking any chances). Symptoms were puking under load and engine fan running when under load. There was a 25 deg difference between the oil temp and coolant temp. The high oil temp was what was telling the computer to engage the fan,. This was all about 6000 or so miles ago and all is well. Went through NJ inspection clean but I don't think that they are looking too hard yet.
Old Jan 29, 2010 | 09:29 PM
dave at BD Power
Former Vendor
Oil field trucks have a hard life... any information you can give on Positive Air Shut Off's. I know its off topic, maybe you can PM me. We are having troubles confirming how mandatory they really are. We just released one and are having troubles getting straight answers. Thanks
Old Jan 29, 2010 | 09:43 PM
Dsl_Burner's Avatar
Dsl_Burner
I've only done one job where I was required to have one and nobody checked to make sure it was there. I'd imagine Ft. McMurry would be a little more strict on it though.
Now back to my problem. I have a blown egr cooler and want to pull it out and weld both ends shut. Will this work or is there other issues?
Old Jan 30, 2010 | 09:03 AM
DSMMH's Avatar
DSMMH
If you have a blown EGR cooler you will have to replace it. Even if you weld both exhaust gas flow ends shut you will still have a coolant leak. Or maybe not. I guess the exhaust gas chamber would eventually fill with coolant but that would probably not be good.
Anyway, after I installed the studs, I verified my exhaust in the coolant problem went away with a Combustion Gas Analyzer Kit. But I still had minor puking. So I rebuilt the oil cooler and pressed a 1.375" freeze plug into the EGR cooler exhaust gas inlet. I have the early build ROUND EGR cooler. Not sure what size freeze plug the later build square EGR cooler would take. Maybe the same one. That is the cheapest and easiest way to stop exhaust gas flow through the EGR cooler and still keep the EGR components in place. It costs you your time, turbo/EGR cooler gasket kit and a freeze plug. Cured my post stud install puking problem.
DSMMH
jimbo1969
Jul 26, 2016 10:03 AM
camper415
6.7L Power Stroke Diesel
Jul 19, 2016 06:42 PM
allingeneral
Mar 10, 2014 06:01 PM
joejackF250
May 21, 2013 08:31 PM
2stroke
Feb 18, 2011 01:05 AM
