Sponsored by: Real Truck
UPFITTER SWITCHES
Old Jan 28, 2010 | 04:44 PM
dusty33's Avatar
dusty33
UPFITTER SWITCHES
How are you suppose to hook up to those upfitter swithes if you want to use them? What are you guys running off your switches? I just got a grille guard and was thinking about running a set of KC's off of the switches but didn't see how to hook into them!
Old Jan 28, 2010 | 05:00 PM
Dan Jordan's Avatar
Dan Jordan
under the dash on the drivers side is 4 wires capped off with shrink tube. the owners manual tells which color is which switch and how many amps the fuse is. i have a set of spot lights mounted on a home made head board on my 08 plow truck for seeing behind me at night works great. because they work off the ignition you don't forget to turn them off and kill the battery.
Old Jan 28, 2010 | 05:03 PM
Wagion's Avatar
Wagion
Pre 2008
https://www.fleet.ford.com/truckbbas/non-html/Q117.pdf
2008 and newerhttps://www.fleet.ford.com/truckbbas/non-html/Q117.pdf
Old Jan 28, 2010 | 05:04 PM
Wagion's Avatar
Wagion
There is also a set of wires that pass through the firewall that are capped with shrink wrap on both ends located under dash by steering column on driver side and on driver side near back of engine compartment
Old Jan 28, 2010 | 05:22 PM
dusty33's Avatar
dusty33
Thanks guys for the help!!!!!!
TakeItEasy
Mar 27, 2013 06:44 PM
scrdanis
Feb 20, 2011 07:09 PM
villestrip
Jul 11, 2009 02:02 PM
Froglips
Sep 14, 2008 08:23 PM
RadarRick
Electrical Systems/Wiring
Jan 14, 2008 07:34 PM
