Sponsored by: Real Truck
Upfitter switches
Old Sep 12, 2008 | 06:56 AM
Froglips's Avatar
Froglips
Upfitter switches
What do you do with your upfitter switches?
Old Sep 12, 2008 | 07:10 AM
a64armt's Avatar
a64armt
I use mine for entertainment when sitting at stop lights or when waiting in line at the McDonald's drive-through. BUT THE'RE MINE, and no one else can touch them!!!!!! The lights amuse me as well.
I am still deciding if I want to install an additional set of driving lights, I would use one for those, but as of now, they just keep me busy when I am bored. I am a simple minded sort.
Vincent
Old Sep 12, 2008 | 08:29 AM
FTX's Avatar
FTX
#4 High Idle, # 3 Power supply for backup camera. 1 & 2 unused at the moment. but will most likely be used for additional rear work lights and front driving lights
Old Sep 12, 2008 | 09:43 AM
NorCalBusa's Avatar
NorCalBusa
Mine turn on the little yellow lights in the end of each switch!
Old Sep 12, 2008 | 10:47 AM
brmpipes's Avatar
brmpipes
#4 is for high idel and #3 is for my tidy tank pump and #1 powers my 2way radio and #2 is unemployed at the moment but looking for something to do ha.
Old Sep 12, 2008 | 11:50 AM
riggz's Avatar
riggz
#1 Emergency Lights (Red/White LEDs and Strobes)
#2 Air Compressor
#3 KC 130w 6x9" Long Range Lights
#4 High Idle
Old Sep 12, 2008 | 02:47 PM
12ozd's Avatar
12ozd
Old Sep 12, 2008 | 05:06 PM
Nice Work Truck's Avatar
Nice Work Truck
#1 Piaa 520 driving lights
#2 reverse lights
#3 air compressor
#4 future control for mirror heaters
Old Sep 12, 2008 | 08:01 PM
TheSnowback's Avatar
TheSnowback
#1 is for my surface to air missles. #2 is the passenger seat ejector module. #3 oil slick/smoke screen #4 activates the brass stripper pole and disco lights in the bed.
Froglips - spend any time in SW Michigan? Once knew a fishing junkie that went by that handle from time to time.
Old Sep 13, 2008 | 12:49 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
#1 is backup lights. Gonna use it as a trigger for a relay as soon as I can get some KCs pointing backwards instead of fog lights zip tied to the bumper.
#2 will eventually be a trigger for a bunch of Highlighters pointing every which way but backwards on a relay.
#3 is high idle (battery charging, not PTO)
#4 used to be a PIE but its on a hot-with-key-on wire now. Maybe I'll add an air compressor and air horns. Or a 12V transfer tank pump on a relay.
Old Sep 13, 2008 | 07:33 AM
Froglips's Avatar
Froglips
Thanks guys. The truck has to go in for some warranty work (one window control sticks) and I thought to have the upfitter switches installed (their "bay" is too small to do another else with!).
How does one hook up the "high idle" switch?
We haul horses. I don't understand how the switches hook into the wiring harness. Would it be possible to control lights on a horse trailer? It would be nice to be able to power up the loading lights on the trailer w/o turning on the headlights.
Thanks,
Froggie
Old Sep 13, 2008 | 09:05 AM
fherb's Avatar
fherb
#1 Rocket launcher
#2 Under Water Mode
#3 Eject Noisy Passengers (At least as far as my kids are concerned.)
#4 Self Destruct (Do not use.)
Old Sep 13, 2008 | 10:12 AM
Grey 250s's Avatar
Grey 250s
#1 reserved for that compressor I want
#2 for rear floods
#3 for high idle (search under SEIC, good directions for a simple hookup)
#4 relayed to driving lites
Old Sep 14, 2008 | 05:53 PM
uncas's Avatar
uncas
#1 powers the aftermarket fog lights
#3 powers the GPS and Radar detector
#4 powers the back-up camera
Still trying to figure out what to do with #2 - may use it for passenger ejection seat.
Old Sep 14, 2008 | 06:40 PM
heymrdj's Avatar
heymrdj
I see people have a high idle switch. Like a previous poster I'm curious how one adds this to a truck, and is it possible to add to a gasoline engine such as my 2004 Expedition or my buddies 2006 F-150 XLT.
