Pullin Power!!
Old Jan 28, 2010 | 12:10 AM
bill11012's Avatar
bill11012
Modular motor junkie
dots? You mean the DPS?
Old Jan 28, 2010 | 12:11 AM
wreckinball's Avatar
wreckinball
Originally Posted by bill11012
How much are you paying for yours? I got a price on having that done and they want $250.
Please post a sound clip too.
hijacker i know, sorry, i am doing it myself, just got a Lincoln electric mig pak 10. That and the two in two out 3" flowmaster or cherry bomb, all of it will come out to less than 150. well that is aside from the 350 i paid for the welder hahaha!
Old Jan 28, 2010 | 12:19 AM
starmilt's Avatar
starmilt
Oh no I am talking about the diesel gods. I was in the dump truck busines when I lived there. But in them days troopers gave me hell to but that was in my hot rod, and fast bike days.
Old Jan 28, 2010 | 12:21 AM
bill11012's Avatar
bill11012
Wrecking ball, I can weld it, its the pipe bending I don't know about.
I think I am going to strait pipe it.
Old Jan 28, 2010 | 12:30 AM
wreckinball
A manual setup would enable you to do but the strength required to bend 3" would be a lot! i am just going to weld in 12.25-22.5 degree elbows and keep it simple! If it breathes like straight pipe, well then it is!!!
Old Jan 28, 2010 | 12:38 AM
bill11012's Avatar
bill11012
Wow, I never thought of that!
I was thinking it had to be bent, but I can just weld in elbows.
Thanks!
I still dont know if I will have them both come out the right side infront of the wheel or a stack on either side of the cab, up as high as the front of the flatbed.
Old Jan 28, 2010 | 12:49 AM
starmilt's Avatar
starmilt
I have a bender with 3" dies is is not hard to bend, but I can't bend real sharp.
Old Jan 28, 2010 | 12:54 AM
wreckinball
Thanks!
well now that is the question isnt it!?
Old Jan 28, 2010 | 12:55 AM
wreckinball
Nor do you want to!!! hahah
Old Jan 28, 2010 | 01:09 AM
bill11012's Avatar
bill11012
Yes, and I don't know which one to do!
Trust me, I know all about that.
I need to price all the elbows it will take.
buying my own bender may be a better deal.
Old Jan 28, 2010 | 01:13 AM
starmilt's Avatar
starmilt
I have a cheap 20 ton bender from harbor freight but it works, my son has used it quite a bit.
Old Jan 28, 2010 | 01:20 AM
bill11012's Avatar
bill11012
I have seen it in there flyer and that is exactly what I was thinking of.
Its $100, $70 on sale, IIRC.
Old Jan 28, 2010 | 01:26 AM
  #28
starmilt's Avatar
starmilt
Seems like they had 2 different ones a 12 ton and a 20 ton, I think I paid around a hundred bucks for the 20 ton.
Old Jan 28, 2010 | 02:32 AM
  #29
David85's Avatar
David85
We have one of those benders and be warned that they usually will just crumple a steel pipe. You need to use a soft grade steel and also a relatively thick wall. The bender will also collapse the cross section even if the bend is done properly. For slight changes in direction, they work ok, but you will find yourself constantly changing position to gradually curve the length of pipe instead of making one isolated, clean bend.
I have done both methods and prefer the elbow method, but to be completely honest, I was using stainless steel which is a fairly hard material. I used a Tig welder, but a mig works great too. This is thin material relatively speaking. Something to remember is you can cut 90 degree elbows down to 45 or less to get away with using fewer elbows. I usually only need 3 90s for a single pipe that drops out behind the rear wheel.
Old Jan 28, 2010 | 09:36 AM
  #30
HORSINROUND's Avatar
HORSINROUND
I have removed the soup bowl and yes its the stock y-pipe but right at end of it i went 3 inch straight back, turn out behind rear tire, this morning he started surging a lot, it was like i was getting a lot more power from nowhere, it almost acted like the fuel was doin something but i dunno havent tore into it yet, any ideas? And im plannin on doing the cowl this weekend
