Pullin Power!!
Old Jan 28, 2010 | 10:12 AM
  #31
starmilt's Avatar
starmilt
Either a stopped up filter or an air leak will make it surge.
Old Jan 28, 2010 | 10:30 AM
  #32
jedstamm's Avatar
jedstamm
What are you guys talking about when you say gettin rid of the soupbowl?
Old Jan 28, 2010 | 10:51 AM
  #33
starmilt's Avatar
starmilt
The soup bowl looking thing in the air cleaner.
Old Jan 28, 2010 | 11:12 AM
  #34
wreckinball's Avatar
wreckinball
In this picture on my site you can see how the bowl is cut off. It is left rear of the lid. Looking at the lid, it is upside down.
http://chiefwhitaker.webs.com/apps/p...otoid=65231616
Old Jan 28, 2010 | 11:39 AM
  #35
HORSINROUND's Avatar
HORSINROUND
It had a lot more power when it was surging, i accidentally hit the fuel switch when i got out of truck this morning, but i turned it back right when i did it, could that have something to do with it?
Old Jan 28, 2010 | 12:18 PM
  #36
starmilt's Avatar
starmilt
Sounds like you have a small air leak or the tank vent can also be clogged.
Old Jan 28, 2010 | 12:49 PM
  #37
Dave Sponaugle's Avatar
Dave Sponaugle
If you know an electrical contractor, EMT tubing and exhaust tubing are close in size.
They have this cool bender that makes mandrell bends.
If they do big enough jobs I have seen a 4, 5 and 6 inch dies, but we are talking big dollars for those benders capable of EMT bends that big.
The raduis does get rather big with the larger sizes, but so is the radius of prebent fittings.
A while back I was watching an electrical contractor bend 6" rigid metal conduit, basically 6" galvanized pipe.
All I could think was man what an exhaust system I could make with that bender and a couple hours time.
Between the bender and dies, probably about 10 grand sitting there.
Old Jan 28, 2010 | 01:12 PM
  #38
HORSINROUND
Okay now new problem just took it to lunch and now whenever i actually get on the throttle it dang near dies then its okay after a minute, its like its takin fuel faster than it can get it, any idea whats goin on?
Old Jan 28, 2010 | 01:16 PM
  #39
starmilt's Avatar
starmilt
Air leak, tank vent stopped up bad filter or possibly a bad pump. check your fuel pressure and flow at the schrader valve.
4 pounds minimum pressure and 1/3 pint in ten seconds.
Old Jan 28, 2010 | 01:17 PM
  #40
starmilt's Avatar
starmilt
What is the weather like, fuel could also be trying to gell.
Old Jan 28, 2010 | 01:42 PM
  #41
bill11012's Avatar
bill11012
Modular motor junkie
I have seen them, but I don't know anyone with one.
What do you think, up both sides of the flat bed at the back of the cab or just run them out the right side?
Old Jan 28, 2010 | 01:49 PM
  #42
bill11012's Avatar
bill11012
Is it blowing black smoke while it does it?
Old Jan 28, 2010 | 01:53 PM
  #43
starmilt's Avatar
starmilt
If you know what bends you want most exhaust shops will make the bends for you and also expand the end so your pipe will fit inside for a much more solid weld.
If you have a shop willing to build you a good dual setup for 250 that is only about 50 to 70 bucks more than what i was paying 30 years ago for 2 and 1/4 in pipes.
Old Jan 28, 2010 | 01:54 PM
  #44
starmilt's Avatar
starmilt
Possible air cleaner restriction.
Old Jan 28, 2010 | 02:06 PM
  #45
bill11012's Avatar
bill11012
EDIT: I only posted this once, I don't know what the deal is.
