Sponsored by: Auxito
squeal under the hood
Old Jan 27, 2010 | 10:54 AM
darkmage55's Avatar
darkmage55
i got a 2001 5.4L 4x4. when i start the truck its a loud squeal under the hood for a short second or 2 then it fades. when i am driving and then slow down it squeals. when i just rev the engine while im in park the squeal comes when the engine is slowing down. ive found that when i pressure wash the area of all the pulleys and such, the noise goes away till the water dries. Any ideas? maybe the belt? i just replaced the tensioner so thats not it, and the belt is maybe 3 months old. This started happening after a night of offroading.
Old Jan 27, 2010 | 01:46 PM
1975IH200's Avatar
1975IH200
I would check the idler pully bearing.
Old Jan 27, 2010 | 06:36 PM
steve(ill)'s Avatar
steve(ill)
the belt is slipping on the pullleys. when it is doing it in the driveway, drip a spoon full of water on the belt inside and note that the noise goes away for a minute. You can try washing the belt surface "and the pullye grooves" with soapy water to get any oil or spray lube off, and getting belt to "stick" better to the pulleys. In the end, you might need a new belt if that does not work.. or live with it.
Old Jan 27, 2010 | 06:54 PM
powersmoked's Avatar
powersmoked
+1 on trying to clean the pulleys. the best belt is a goodyear gatorback belt
Old Jan 27, 2010 | 11:01 PM
darkmage55's Avatar
darkmage55
lol unfortuately the belt that is on it is a gatorback, bout 3 month old. must have just been a bad one of the batch!
Old Jan 28, 2010 | 12:16 AM
grego37's Avatar
grego37
i heard the same before, and it was the belt tensioner and idle pulleys
Old Jan 28, 2010 | 11:53 AM
darkmage55's Avatar
darkmage55
well, i dove in further to the issue today. took the belt off, cleaned it, cleaned all pulleys, reassembled everything, and the squeal was still there. so i took a screw driver and touched it to the alternator and listened to the handle of the screw driver and now i believe that the alternator is possibly making the noise. And suggestions? Do i need a new alternator or can i replace bearings in there?
Old Jan 28, 2010 | 02:57 PM
KingRanchMan02's Avatar
KingRanchMan02
Could be but, I have read other threads where a problem like this was caused by the harmonic balancer assembly. There is as rubber insert that the pulley is pressed onto over the balancer. It deteriorates and allows the pulley to shift slightly causing a mis-alignment of the lower pulley with the rest of the pulleys on the engine. Requires a new harmonic balancer assembly. Good luck!
Old Jan 28, 2010 | 05:45 PM
fordtech08's Avatar
fordtech08
did you listen to your idler?
Old Jan 28, 2010 | 09:38 PM
darkmage55's Avatar
darkmage55
yes idler is just fine, its fairly new
Old Jan 28, 2010 | 09:42 PM
steve(ill)'s Avatar
steve(ill)
original post said when wet, the noise stopped.... what has that got to do with alternator?
Old Jan 28, 2010 | 09:48 PM
fordtech08's Avatar
fordtech08
if when the belt is wet and the noise goes away I'd have a hard time believing it's the alternator bearings, it's probably the belt dried out or the paint has worn off your idler pulley,
good call steve
Old Jan 29, 2010 | 01:31 PM
darkmage55's Avatar
darkmage55
no idea. still trying to diagnose it. seems like things change every day.
Old Jan 29, 2010 | 03:07 PM
KingRanchMan02
Harmonic balacer.
Old Jan 29, 2010 | 03:43 PM
darkmage55's Avatar
darkmage55
what pulley is the harmonic balancer under?
